Old 04-12-2010
weephee is on a distinguished road
Lexan VS Acrylic
I am replacing the smoked cover on my hatch. I don't know what material it is but I do have a piece of smoked acrylic available to me. Area is 20 inches x 20 inches with two parallel support pieces running 5 inches apart under it. Is it OK to use the acrylic or should I be looking for a piece of Lexan. Thanks
Old 04-12-2010
Most hatches use cast acrylic, not lexan, with the exception of a single line of Bomar hatches IIRC. What kind of port is it? How thick is the piece you have?
Old 04-12-2010
JohnRPollard's Avatar
Moderator
Our Bomar hatches are polycarbonate (Lexan). Most other hatches I've worked on were too.
Lexan is stronger but less UV resistant than acrylic. Acylic is often used for smaller portlights, whereas Lexan is preferred because of its strength for larger areas like hatches.
For a 20"x20" opening, I'd use Lexan/polycarbonate, not acrylic.
Old 04-12-2010
JRP—
I doubt that... Most hatches are cast acrylic because polycarbonate foreshortens when it flexes under impact, making it very unlikely to remain sealed. If you check with Lewmar, one of the larger hatch producers, all of their specs mention the thickness of the acrylic... not lexan or polycarbonate.
Old 04-12-2010
PeterSailer's Avatar
Bathurst NB
PeterSailer is on a distinguished road
I don't know about acrylic but Lexan is very easy to scratch...
Keep It Simple!
Old 04-12-2010
Moderator
SD,
Has that always been the case? I guess I've worked on a few hatches in the past, all of them older and in need of work due to UV degradation. I recall them being polycarbonate.
I also recall when researching a material to use for our portlight lens-replacements (in our previous boat), that acrylic was considered a good fit for portlights, but that polycarbonate was recommended for hatches or larger deadlights.
Maybe there has been a shift in newer hatches to acrylic, or is it that some of the "value" oriented designs use this less expensive material for the lens?
Here's one that is similar to ours, which uses polycarbonate:
BOMAR CAST ALUMINUM HATCH # 139L. 24 " X 24" BLACK
Old 04-12-2010
acrylic- more scratch and uv resistant
Lexan- more impact resistant
Old 04-12-2010
Originally Posted by JohnRPollard View Post
SD,
Note the reinforcing bars—they're to prevent the polycarbonate from flexing enough to break the seal. Yours are the one kind made with polycarbonate. All the others are acrylic.
Old 04-12-2010
erps's Avatar
the pointy end is the bow
Which one bends with some heat? I've seen some do-it yourself projects using one of those materials. It looked easy to cut and easy to shape but I can never remember which one.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 04-12-2010
Both will bend with heat. Both are fairly easy to cut and shape.
Acrylic Retailer in the NYC Area brob76 Gear & Maintenance 4 04-01-2010 06:09 PM
Replacing windows Dick Pluta Gear & Maintenance 30 02-03-2010 05:58 PM
Lexan Replacement Hatch for C30 latitude9.5 Gear & Maintenance 1 07-04-2006 12:14 PM
Rebedding leaking lexan ports jhoover3468 General Discussion (sailing related) 12 12-01-2003 09:17 PM
Restoring Lexan Surfaces Sue & Larry Gear and Maintenance Articles 0 02-10-2002 07:00 PM
