Question for current or former Ketch owners (only) - Page 2 - SailNet Community
post #11 of 21 Old 04-15-2010
CaptainForce's Avatar
I've been on my current ketch since 1985. If the selection of rig were the only criterium, I would probably select a cutter, but there are always other factors and compromises. You don't see many split rigs in production today in part because the technology for sail handling has reduced the struggle for an individual to deal with a large sail. I find one of the greatest advantages of my ketch is passing under 55' fixed bridges that would block any sloop with my LOA. 'take care and joy, Aythya crew
CaptainForce is offline
post #12 of 21 Old 04-15-2010
christyleigh's Avatar
Actually my NC has the deck and mast attachments to make it into a Cutter also. It could be argued that my foredeck isn't long enough to be called a "Cutter" and I would only be adding a "Staysail" but with the genoa out there on that sprit the dimensions could be close to correct for "Cutter" rig. Whatever....... I did a test with a line (the inner sail halyard that is already set up in the mast for the "Cutter"/ stay sail) running from deck to mast and after getting the genoa hung up on it once (as I figured would happen) I said Nope..... no cutter aggravations for me. I'd like the extra sail area but not at the $$$$ and tacking price of adding the stay.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #13 of 21 Old 04-15-2010
Originally Posted by christyleigh View Post
Actually my NC has the deck and mast attachments to make it into a Cutter also........
I assume you were thinking of making your vessel a Cutter-Ketch. I have no goals or anything to gain in altering my ketch either. I was just thinking of my choice with a totally new boat and no consideration other than rig. I, along with others posted above, am very pleased with my ketch; however, I do recognize that it would not be suitable for the racer. 'take care and joy, Aythya crew
post #14 of 21 Old 04-15-2010
TQA
Bombay Explorer 44
TQA's Avatar
I had a 38 foot steel ketch for 7 years ft cruising. I really liked the ability to drop the main and still have a balanced sail combination that the autopilot could handle with ease.
I was looking for a ketch as my forever retirement boat but finished up with a really nice boat that is a cutter. If I was doing more long distance stuff I think I would have persevered until I found the perfect ketch.
TQA is offline
post #15 of 21 Old 04-15-2010
okawbow's Avatar
I am refitting a Cheoy Lee 31 ketch. One thing to think about is the extra work and expense of a second mast. My boat has 14 chainplates. It has 16 rigging wires. More sails, more running rigging, etc.
I bought my boat solely for a trip down the Mississippi/Tom Biggbee waterway, and then a couple of long offshore passages. I wanted the ketch rig to reduce the sail size and aid self steering.
Chuck
Privateer 26 Schooner
okawbow is offline
post #16 of 21 Old 04-16-2010
CrazyRu's Avatar
I have a Cat Ketch. I love the rig, I don't want anything else for long range short handed cruising. Ketch is the rig for strong winds.
However, last season I used the boat mostly for day sailing. I missed single mast.
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
CrazyRu is offline
post #17 of 21 Old 04-16-2010
Allanbc's Avatar
I've owned my first ketch since October. I am still learning about the rig. So far, I really like it and like the ability to use many different sail options. I like being able to run "jib and jigger" for easy. The main is smaller and it is quicker and easier to set. I'm sure I will dislike my ketch when I replace the sails!
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
post #18 of 21 Old 04-16-2010
Ilenart's Avatar
Patrick,
I have just sold my 45 ft ketch and in the process of finalising my next purchase, so I guess I fit into your criteria. Next boat I am looking at is a 39ft sloop rigged S&S designed cruiser / racer. However a big criteria for me was looking for a yacht I could single hand. I decided a slightly smaller rear cockpit sloop or cutter rig would be a lot easier to handle.
Where I sail we often have a fair bit of upwind work and I found the ketch rig was not a good rig for handling these conditions. Nine times out of ten we would not use the mizzan for the upwind work.
Like others have said, if you are planning lots of long reaching or downwind legs a ketch rig could work well. However if you are looking at upwind legs, coastal trips or day trips I would look at a sloop or cutter rig.
Ilenart
Ilenart is offline
post #19 of 21 Old 04-18-2010
Rob Hills
I have a 39' ketch, as it happens she's about 10 boats along the jetty from the one Ilenart's just sold. I've owned her for over 10 years now and if I were buying a new boat, I suspect the rig wouldn't be a major determining factor in my choice.
Like others, I like the way I can "reef" by simply dropping (or not hoisting) the main and sailing under headsail and mizzen alone. Our boat doesn't point any better with the main than she does without. I'm not convinced that the ketch rig is the cause of poor pointing with my boat - she's quite beamy with the main side-stays attached at the gunwhale and the headsail sheeted outside, hence a big angle of attack.
A couple of things to watch out for:
1. A ketch rig often means a centre cockpit which often also means less headroom under the boom, both when sailing and when at anchor. This may or may not be an issue for you.
2. On my boat, the mizzen boom overhangs the transom which creates complicates lots of things you may want to do with that space - wind vanes, davits, solar panels, wind generators etc.
HTH,
Rob Hills
rhills is offline
post #20 of 21 Old 04-19-2010
.....or.... It could make things easier. It doesn't interfere with my davits and I run the Mizzen Halyard through a block on the Davits for my wife to lower and raise my 100 lb outboard with the Halyard Winch while I'm in the dingy. Last year when they switched to Digital TV I put an antenna on top of the mizzen mast. That's where my Radar lives and one of these days I'll put a Wind Generator on a swivel mount up there above the Radar. And another ... one of these days things will be Solar Panel on top of my davits. So..... for me - nothing but benefits
Stan
'Christy Leigh'
NC 331
Question to Catalina 350 owners jackm1954 Boat Review and Purchase Forum 8 02-09-2015 06:54 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
Datamarine Owners a Question halyardz Gear & Maintenance 5 05-04-2002 09:07 AM
A question to all boat owners Apollo18 Crew Wanted/Available 6 12-31-2001 08:14 PM
