to Swing or Not to Swing ... keel that is - Page 3 - SailNet Community
post #21 of 31 Old 04-22-2010
One of THOSE!
2Gringos's Avatar
Just curious, but haven't these boat builders heard of stainless steel? Its this new stuff that doesn't rust up as bad. Lots of people have been using it.
Expat Life in the Devil's Triangle:
2Gringos is offline
post #22 of 31 Old 04-22-2010
Sunsets and Warm Beer....
LandLocked66c's Avatar
Originally Posted by BarryL View Post
From the Catalina 22 Owner's Manual:
You'll face special problems if you decide to keep your retractable keel model in the water, especially salt water. Bottom paint is a must, plus periodic cleaning and removal of marine growth from the keel trunk slot. The possibility of corrosion to the keel and keel fittings is greatly increased. Keeping a retractable-keel model in salt water for lengthy periods is not recommended.
Barry
Catalina covers all there bases, huh?
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #23 of 31 Old 04-22-2010
Broad Reachin'
kwaltersmi's Avatar
Originally Posted by nogin View Post
I guess the saving grace there is I can bring the swing keel to the dock and trailer her out to the side and without having to take anything down, clean the bottom and paint where necessary.
Just keep in mind that the swing keel/center board isn't accessible on most boats when they are on the trailer. You'll likely need to get some time in the sling to paint and inspect the board.
Catalina 34
kwaltersmi is offline
post #24 of 31 Old 04-22-2010 Thread Starter
... not so convenient then huh???
nogin is offline
post #25 of 31 Old 04-22-2010
Buying a boat is full of compromises. Just like being married!
S/V Frida
post #26 of 31 Old 04-22-2010 Thread Starter
Yes but being knowledgeable and weighing all your options will lead to many happy years ahead!! I know from being married and owning a power boat.
nogin is offline
post #27 of 31 Old 04-22-2010
I chose the centerboard route. It's trailerable, easy to store and small. It will be used primarily in fresh water. It's 40 years old and the centerboard still functions normally. I plan to gunkhole and sail sheltered waters so all of this led to our decision. Once you narrow down how you'll use the boat you'll be closer to determining what works for you guys.
S/V Frida
post #28 of 31 Old 04-22-2010 Thread Starter
If I were in your situation that would be my clear choice as well. However, I will be in the LI Sound and Eastern Sea Board so deep water a plenty. I was just considering the swing keel to reduce some haul, storage and mooring fees but it seems like it would be a PITA getting her all rigged up ready to sail each time we go out. Keeping a swing keel at the mooring is not an option for me at this time considering all the feedback from fellow forum members.
Thanks everyone!
nogin is offline
post #29 of 31 Old 04-22-2010
I don't discuss my member
zz4gta's Avatar
I didn't read the whole thread but I'm a big fan of lifting keels. Antrim 27, and a few others that lock in place when they're down. I believe its a more modern and better design.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #30 of 31 Old 04-22-2010
P8dawg's Avatar
I owned an S2 8.0 shoal keel. I loved it when my lake gets shallow in August, but the rest of the time it made it too easy to knock that boat flat in a gust. It's all give and take. I had to replace the hoisting cable once. Other than having to bring up the board with a cargo strap so I could back out of the slip, it was a fairly easy job.
"cause the fast ones always ride for free." -Mother Love Bone-
P8dawg is offline
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 07:52 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 10:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 08:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
Swing Keel Dilemma SailNet Gear and Maintenance Articles 0 07-12-2001 09:00 PM
