05-06-2010
If you can't comfortably afford the costs of storing and berthing a boat, then buying one is probably a really bad idea. That said, is there any particular reason you need to be in that harbor? That harbor doesn't look like it has much in the way of protection or facilities.
Morro Bay, which is only about 40 miles or so away, is probably a far better place to keep the boat, since it is very well sheltered.
