Old 05-11-2010
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
Radio ID question
If your boat has a name, but the name is not on the hull anywhere (no lettering), what is the proper way to make a radio call to a marina or whatever? I'd think you'd use the name in the initial call so that whomever you are calling would have a "handle" with which to call you back, but at some point I'd think you'd have to say "28 foot sloop with navy blue hull" so that they'd have some way to get a visual ID on you as well.
Is there a protocol for this situation?
Thanks!
S/V Free Spirit
Monrovia, MD
Old 05-11-2010
tomandchris is on a distinguished road
I think you answered your own question. That is exactly what I would do. You are XYZ until you are describing yourself, then you are lenght, beam, and keel depth for seeking a slip at a marina and you are XYZ, a 27' sailing vessel with navy hull for the coast guard in an emergency.
Old 05-11-2010
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
Also, vessel names are often on the stern, and when approaching a marina, if they are trying to get a visual on you, they will not be able to see the stern anyway, so a description will likely be required whether the name is on the vessel or not.
In an emergency coast guard hull, a description will also be necessary, since it is hard to read names from a long distance. In that instance, I would probably also mention the name is not on the hull, since if they are trying to find you among other boats, they may assume it is not you if they do not see the name they are looking for.
S/V Lilo
1964 Islander 32
Saint Helens, OR
Old 05-11-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
On Channel 9
You say; "Marina (or whatever), Marina (or whatever) this is S/V Free Spirit on channel 9."..."Marina (or whatever), Marina (or whatever) this is S/V Free Spirit on channel 9." ... (wait 2 min)
Marina (or whatever) responds; "This is Marina (or whatever) to Free Spirit."
You say; "Marina (or whatever) do you have a preferred channel?"
Marina (or whatever) responds; "Our working channel is channel xx."
You say; "Thank you. Please switch to Channel xx."
Marina (or whatever) responds; "Switching to channel xx."
switch to channel xx
You say; "Marina (or whatever), Marina (or whatever) this is S/V Free Spirit on channel xx."
Marina (or whatever) responds; "Go ahead Free Spirit."
You say; "We are a 28 foot sloop with navy blue hull. We have an x foot draft, and are y feet long..."
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 05-11-2010
Here the marinas answer with "Free Spirit, this is XYZ marina, please switch and answer on Channel X". They move you immediately to their working channel unless you called them on it..
Old 05-11-2010
eherlihy's Avatar
Realize that the dialog above was for a marina, or whatever.
Hail on the working channel (preferred), or hail on channel 9 then move to working channel.
Old 05-11-2010
bacampbe is on a distinguished road
I know 9 is a hailing channel, but how often do people find the marina ( or whatever) actually monitoring it?
s/v Dancing Days
Beneteau 31
Lewisville Lake, TX
Old 05-11-2010
Speaking only for Lake Michigan, but most marinas monitor 16 and their working channel which is usually listed in the guides. Some also monitor 9, but many do not.
Old 05-11-2010
ronspiker's Avatar
ronspiker is on a distinguished road
I've never had a problem with them not listening. If ch 9 fails then ch 16 will work but I've never had to do that
Old 05-11-2010
J36ZT is on a distinguished road
I've found Channel 16 to be much more effective than Channel 9 in making initial contact. Obviously, the switch to another channel must be made immediately unless it's an emergency. There are areas that utilize certain channels for specific purposes (bridges, vessel traffic, etc).
In any case, I was taught to repeat the party you are trying to reach three times, followed by who you are. You could use your vessel's name, state registration numbers (ie CF 1234 XX), or an official call-sign. I think everyone will agree, someone would have to be pretty close to be able to read the registration numbers or vessel name...and by then it's too late. Sail numbers are a help and these are frequently used during races. Keep in mind that many people won't have a clue in being able to tell one brand sailboat from another (ie Islander, Farr, J-Boat, Catalina, Ericson, etc), and still others don't know the difference between a sloop, cutter, ketch, or yawl.
All I can say is do your best... "Marina X, Marina X, Marina X...this is Zero Tolerance." ...Marina X: "what is your location?" ...Zero Tolerance: "I'm the sailboat circling at your enterance..." This seems to have worked well so far.
Skipper, J/36 "Zero Tolerance"
High-Frequency Radio Basics Kathy Barron Seamanship Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Gear and Maintenance Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Her Sailnet Articles 0 10-14-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Gear and Maintenance Articles 0 09-28-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Cruising Articles 0 09-28-2000 08:00 PM
