05-22-2010
I think that a set up from another boat may well not work. Being just a little off could be a problem. I think that just a bit of uneven weight distribution would be magnified in a turn.
One thought: Make sure the stantions supporting the bunks can be easily moved. Get them very loose. move them out, meaning farther from the midline. Have the boat lifted out, and put on trailer, weight on the center, balanced by the lift straps. Move the bunks in to balance boat and secure. I would probaly have the crane lift the boat a teeny bit to move the bunks in a teeny bit beyond the initial contact point. This might work
Alternately, remove bunks. Have pipe the size of a boat stand welded, at a bit of an inward angle, X 4. Put the top portion of 4 boat stands into place, and adjust accordingly. I did this to adapt a Rodes 22 trailer for a Tanzer 22. Make sure the forward stop on the trailer (meaning where the winch is mounted.) is easily moved. With a bit of experimentation, this can be done without a crane. I did.
Sory, no pics, that boat and trailer are gone.
Good luck. be careful.
