Old 05-23-2010
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Finally sailing again after a long winter
Hi everyone,
Almost a year and a half ago, we bought our 1984 Sabre 34 in Connecticut. In May 2009, we sailed her home to Maryland. Although we worked hard on the boat that first winter, our goal was really centered around getting her ready for the trip home. So this past winter, at the end of our first year of ownership, we had a lot to do.
As most of you know (or experienced yourselves), we had a pretty rough winter around here. So therefore most of our projects started much later than expected. The result was that we splashed our boat just last week, way over a month later than planned. After a tough winter and spring working on the boat, we had our first sail of 2010 this past weekend. And a lovely two days of sailing it was. Even though we had some rain, it held off at all the right times, and we our sailing was mostly reaching at 6-7 knots. Friends on board, great conversation, and food. A fine weekend for sure to kick off the season.
But if you don't mind, I want to write about what my wife and I accomplished this winter, if for no other reason than to list it out for ourselves, and post it for other sailors who understand the experience of novice owners learning to do our own work on our boat. I hope you don't mind! We learned a lot, which was most gratifying. We also worked very hard, which was tiring. At times, it seemed like we'd never finish.
Below is a list of what we did in no particular order, which we did alone, except where noted:
  1. Completely stripped, sanded, and refinished all exterior teak (handrails, toerails, cockpit coamings, anchor platform, drop boards, and cockpit trim)
  2. Removed handrails, sealed core leak with epoxy, and reinstalled (included 52 teak bungs removed and replaced)
  3. Rebuilt the mast step and improved water drainage (had help with this)
  4. Installed halyard restrainer on mast to prevent halyard wrap
  5. Installed Windex (boat didn't have one)
  6. Removed and rebuilt Datamarine masthead wind unit (DMI did the rebuild)
  7. Removed and inspected masthead assembly
  8. Inspected rig (had pro rigger do this, but followed along and learned a lot)
  9. Sanded and prepped bottom
  10. Painted bottom
  11. Cleaned, prepped, and painted prop/shaft
  12. Replaced centerboard pendant
  13. Sanded and painted centerboard
  14. Removed and repaired hour meter (had a shop do repair to the meter)
  15. Replaced clinometer
  16. Removed Loran at nav station and antenna and all associated wiring
  17. Removed nav station chartplotter (no chart chip available anymore) and associated wiring and antenna
  18. Built teak enclosure at nav station and installed new stereo/CD player, new VHF, and two 12V jacks (boat didn't have any jacks before, and stereo and VHF were all exposed with wiring showing)
  19. Replaced emergency tiller cover, including sealing core and beveling holes
  20. Installed Hella fans in cabin
  21. Removed and rebedded spinnaker pole mounts (including sealing core where possible and beveling all holes)
  22. Replaced furling line bullseye fairleads with blocks
  23. Replaced reefing lines (still need to be spliced)
  24. Installed mast cheek blocks for lazy jacks (still need to build out the lazy jacks)
  25. Polished cleats and other hardware that was removed for other work, replaced bolts, nylock nuts, as necessary
  26. Removed and inspected 6 shroud chainplates, ended up replacing them (of course had these made), installed, and rebedded
  27. All sails inspected and cleaned, and batten pockets on main reworked to prevent snagging on topping lift (sail maker did this)
Of course, I would be remiss without thanking Sailnet members, other sailors at our local yard, family, friends etc. for advice and input when problems popped up. Thank you!
I realize that some owners do and have done so much more than we did this year. For us, it's just nice seeing it all in one place, though I'm guessing I left a lot of little things out. Thanks for "listening", and thanks again for your help!
Cheers,
J
1984 Sabre 34 Mk I
Old 05-23-2010
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
More then I did...well done!
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Old 05-23-2010
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
That is an impressive list, way to go!
I hope you have a great summer and enjoy the boat.
What are you pretending not to know ?
Old 05-23-2010
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
Whew! I'm exhausted just from reading the list Jim. Well done and I'm glad you finally got out to sail. All the best and looking forward to seeing the fruits of your labor sometime soon.
All the best...MGM
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
Old 05-23-2010
josrulz's Avatar
Unpaid Intern
All the best...MGM
Thanks folks! MGM, we need to get these boats in the same place soon. Thanks again for the input along the way, which was a big help!
1984 Sabre 34 Mk I
Cats on Board slosharron Living Aboard 49 3 Weeks Ago 12:35 PM
Learning to Share PracticalSailor Practical Sailor 14 09-21-2011 02:28 AM
The Advocate - While sailing yesterday on Long Island Sound aboard the Ticonderoga, . . . (Stamford Advocate) NewsReader News Feeds 1 07-31-2009 07:33 PM
Winter sailing class begins soon (Newport News-Times) NewsReader News Feeds 0 01-26-2007 01:15 PM
