Old 05-25-2010
bofus1 is on a distinguished road
Life lines
Can someone please tell me the best way to loosen up pelican hooks and lifeline nuts that have been setting on hard for 5 years? I've tried WD-40 but to no avail. Thank you in advance. Pearson 30 bofus11
Old 05-25-2010
Try Kroil or PB Blaster... these are industrial grade penetrating lubricants. Be careful with them as the will attack rubber and plastic in many cases.
Old 05-25-2010
knothead's Avatar
Spraying with WD, Blaster or any other penetrant will not usually have an immediate effect. If you do it regularly over a period of time, you will have better luck.
If you are just trying to adjust the pelican hooks, try spraying them for awhile, then while holding the swage stud in a pair of vise grip pliers or better yet, a vise with soft jaws, carefully start working the locknut back and forth. If you get movement, keep working it. Don't force it or it might gall or shear off.
You can use a little heat from a torch, but don't overdo it.
If you can get the lifelines off the boat, then you might want to try soaking the fittings is Ospho. It will eat the rust and clean up the stainless.
Truthfully though, if your fittings are seized up, they should be replaced.
Good luck.
Ron Paul 2012
"wikijar"
Old 05-26-2010
Bofus11 here; thanks for the replies- any more will be appreciated
Old 05-26-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Stainless is like aluminum in that it will gall against like metal. It could be that this is your issue. Once ya get them apart, if ya get them apart, replacement is advised. Use an "anti-seize" paste when re-assembling.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 05-26-2010
ambianceack is on a distinguished road
heat gently with propane torch to crack the rust
Old 05-27-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Good luck.
Please listen to Knotty!!! If they are so rusted that they are siezed, you cannot be sure that the rust is the only problem.
The saying "penny wise, pound foolish" certainly applies here. You are literally gambling with the safety of you and your crew here for a relatively inexpensive rigging job.
You can struggle with the existing stuff, and always have that nagging worry in the back of your mind about whether or not the old ones will fail.
Or you can replace the lifelines with new ones and have a secure feeling that they can be depended on to do their job -- helping to keep captain and crew aboard the boat.
Your choice, but I know which one I'd make.
Old 05-27-2010
erps's Avatar
the pointy end is the bow
Don't some of the fittings have backwards threads too? You might be doing a "leftie-loosey" but tightening it up instead. Just sayin'.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 05-27-2010
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
90% of your turn buckles have both right hand & left hand thread. And finding a new locking nut for that left hand thread is nigh on to impossible.
Why you ask a turn buckle has both? Well when you are turning the barrel of said turn buckle both ends move in or out the same amount.
Inspect every turn buckle you have on your boat and you will see what I am talking about.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 05-27-2010
knothead's Avatar
Many, if not the majority of pelican hook studs are left handed.
Boasun, what are the ten percent of turnbuckles that don't have both left and right hand threads?
Ron Paul 2012
"wikijar"
What's the big deal... yachtsea Cruising & Liveaboard Forum 60 08-21-2006 07:09 AM
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
Help Us Test Life Rafts DSRitter Gear & Maintenance 1 07-15-2002 06:01 PM
Spare Dock Lines Mark Matthews Gear and Maintenance Articles 0 03-10-2002 07:00 PM
Here’s the Rub Don Casey Gear and Maintenance Articles 0 11-15-1999 07:00 PM
