Old 05-26-2010
night0wl's Avatar
night0wl is on a distinguished road
What are these called and where do I find them?
Take a look group:
I'd like to get a bunch of these little straps with beads on them for all of my pelican clips for my lifeline gates. I need 6 (2 for port, 2 for starboard gates and 2 for my aft passthrough).
Anyone know what they're called and where to procure them???
S/V Jendai
Beneteau 343
Old 05-26-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Parrel beads.
Duckworks Boatbuilders Supply
Old 05-27-2010
Large Member
mdbee is on a distinguished road
Girlfriend
Had a girlfriend one time that had some of those, in her nightstand.
Never knew what for...
Old 05-27-2010
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
LMFAO!!!
Old 05-27-2010
CLucas's Avatar
CLucas is on a distinguished road
Send a message via AIM to CLucas
I believe they're called "little straps with beads on them." Seriously though, why not do some nice decorative marlinspike work using some paracord -- it would look much more nauti... vs. naughty Take a look here for some ideas: Stormdrane's Blog. The parrel beads described above are much bigger than those in the pic.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
Old 05-27-2010
Allanbc's Avatar
Allanbc is on a distinguished road
They were to pull-start your old girlfriend like an outboard.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 05-27-2010
They're not parrel beads, which are usually much larger. They're basically zipper pulls... and they're there to make pulling the pin on the snap shackle easier.
You can make them using knotwork, as seen here:
Old 05-27-2010
smackdaddy's Avatar
Last Man Standing
I vote parrel beads.
And I want to meet that chick with the nightstand.
BFS Gear: SNers started it....
Old 05-27-2010
knothead's Avatar
Flat White Shackle Pull [ShacklePullFlatWhite] - $2.50 : Little River Crafts, Supplies
Ron Paul 2012
"wikijar"
Old 05-27-2010
FlyingScot1 is on a distinguished road
http://www.lifesavingsystems.com/bas...es/helo4_4.htm
Scroll down a bit and you'll see something similar. At least it's a start
