Old 06-10-2010
Brian24jersey is on a distinguished road
BABA 35 Wooden Deck
I was looking at boat listings and on a old BABA 30 I noticed it had a wooden deck. My question is how hard is it to maintain a yacht with a wooden deck.
Old 06-10-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
It depends. Most have wood in their decks, many sandwiched between glass. The usual issue with wood decks, any decks are where things like cleats, chainplates and other hardware are bolted or pass through. If not properly maintained, they leak. When that happens, the plywood, balsa or whatever soaks up water and turns to mush or rots. If teak over glass, it depends on how it was built. Some teak decked boats were not properly bedded and had screws driven down into the glass/wood sandwich, which later caused the above issues.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 06-10-2010
Thank you sir,
I checked out your website the valient 40 you painted looks real pretty!
Old 06-10-2010
On the hard
Thanks, it's appreciated....
Bellingham, WA.
Old 06-13-2010
vessenes is on a distinguished road
Charlie hit the high points, but you also have to think about Teak maintenance itself, even if it's bedded properly.
If it's left 'natural' or oiled, you're going to be scrubbing it down with oxalic acid periodically and then re-oiling if you like that look (I do!).
I haven't seen many varnished teak decks, but I'm no expert, so I'm sure that can happen as well.
All that to say, even if the fiberglass deck itself is in good shape, keeping a large teak deck in good shape is going to be a non-trivial amount of labor, in my limited experience.
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
