06-11-2010
I don't think it is all that necessary to flush the engine. Hauling it up out of the water is really the most important thing you can do. Once it is out of the water, the fact that it has some salt water still sitting in it isn't a big deal, since the cooling passages that will have the salt water in them are usually made of all the same material, so the galvanic corrosion, which does the most damage to the engine, isn't going to be much of an issue.
