06-20-2010
A lot of what your answers will be, have to do with what you plan to do with the boat.
If you're planning on making bluewater passages, I would recommend getting a boat that does not have a saildrive—especially if you're planning on sailing in more remote areas. While many boats have made bluewater passages with a saildrive, it is probably safer to do so in a boat with a traditional shaft and prop. Also, getting a saildrive serviced in remote areas, especially if the bellows fails, is probably more difficult.
