06-21-2010
Let's see. You have an ST50 transducer. You damaged the display and bought a non-compatible ST60 display, which you've since installed, but don't want to spend the money or time buying and installing a compatible ST60 wind transducer.
Basically you've got two options, neither of which you sound like you'll like, but that's just too bad...cause you don't have any other choices the way I see it. Your choices are:
A) you get a ST50 display that works with your ST50 transducer
or
B) you get a ST60 Transducer to work with your ST60 display
Your real mistake was buying the ST60 display. Getting a used ST50 display would have been a much simpler and less expensive drop in solution, since it would have been really simple to just swap it for the old display—no holes needed to be drilled, no wires need to be run or cut.
