Twin Keel vs Bulb Keel - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 04-01-2003
DuaneIsing is on a distinguished road
Jeff_H,
Besides all the other good info, thanks for teaching me a new word: rodestead. Do you discriminate between "rodestead" and "anchorage"?
Duane
  #12 (permalink)
Old 04-01-2003
megman is on a distinguished road
Well not worried about movement as I would be welding some cross members also into the cavity to eliminate the chance of that. Not sure what the solution would be to eliminate any shrinkage.
I did mention I would be using 1/8" steel for the keel. I should have mentioned that it will be "stainless" steel with stainless welds. This will cut down on the maintenance.
  #13 (permalink)
Old 04-01-2003
Jeff_H's Avatar
Super Moderator
Stainless steel may actually be a worse choice because it is even more prone to crevice corrosion and because it is dimensionally pretty unstable when heated. When you apply heat to stainless steel to stainless it tends to distort and lose fairness. It is also quite difficult to get bottom paint and fairing materials to adhere to stainless steel but stainless steel provides a poor surface for fouling meaning that barnacles can adhere to the stainless steel very tenaciously.
This is sounding like a worse idea with each post. Why not pour the keel and attach it as it has successfully been done for the past two or so centuries. It will be cheaper and easier and have a better result in the long run.
  #14 (permalink)
Old 04-01-2003
Jeff_H's Avatar
Super Moderator
I think that Rodestead (also and perhaps more correctly spelled Roadstead) is interchangeable with anchorage. I used to hear the term used when I was a kid and it was often used for an outer anchorage so that someone might say, "The inner anchorage was full so we anchored out in the outer rodestead." That said I am not really sure that there really is a difference between Anchorage and Rodestead though.
  #15 (permalink)
Old 04-01-2003
One of my main considerations for using steel was that 9"x6" Elm is damn near impossible to get, which is what is called for to build the keel up.
Steel is used for the Twin Keel version. Only stands to reason it should be fine for a single.
I''m just trying to do this with what is available, yet still usable.
  #16 (permalink)
Old 04-04-2003
paulk's Avatar
paulk is on a distinguished road
Have to agree that it would be simpler to leave the lead exposed on the keel and box in the bilge/garboards with steel & floors and bolt the lead assembly to it. Lead is a great cushion if you hit something hard. (We know -- but that''s another story...) If you poke a hole in a steel casing that''s holding your ballast you can develop some nasty problems before you know it. Woodenboat has had several articles on pouring lead keels and moving them around with farm tractors, winches, and tackles. Sounds quite straightforward if you think it through. Unless you absolutely require shallow draft, twin keels are not the way to go. They''re lighter, individually, but imagine the fun you could have making sure they''re both parallel with the hull and each other...!
  #17 (permalink)
Old 05-14-2003
garyp's Avatar
garyp is on a distinguished road
I would think "roadstead" would be the passage into the anchorage, while rodestead would be the anchorage (the place where you drop your rode.)
Just kidding.
  #18 (permalink)
Old 05-15-2003
thefantasea is on a distinguished road
The Merriam-Webster Dictionary carries this entry:
Main Entry: road·stead
Pronunciation: ''rOd-"sted
Function: noun
Date: 1556
: a place less enclosed than a harbor where ships may ride at anchor
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 05:39 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 05:54 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 05:36 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 04:09 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 03:13 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
