07-02-2010
If you plan to tow your boat with this trailer on the highways, there is another set of concerns that haven't been mentioned. What losd is the trailer rated for? Are the springs rated for the load (your boat's weight plus trailer + gear..motor, gas, etc.), are the tires rated for this load, how about bearings (condition/size), and how about the axle? If any of these components go at highway speed, you're in deep trouble.
Also, as you add your extension, you have to maintain proper balance. The boat should sit on the trailer such that the tongue/hitch carries ~10% of the trailer load according to what I have read. This may mean that you have to reposition the wheel assembly or reposition the bunks.
A long extension added to the tonque needs to be heavy/strong enough that the trailer/boat is not flexing up and down when you travel (essentially this is part of your original question), but it can't be answered without knowing details the trailer tubing (dimensions, wall thickness, material, etc.) and doing some calculations that most of us don't know how to do. Anyway, the point here is that you don't want your boat flexing up and down with the trailer on the road.
You might be better off getting some measurements on the boat and buying a trailer that is already suited for the task. If you try to make do with a grossly undersized trailer, you may well have lots and lots of expensive problems. You can always resell the too small trailer to recover your cost in that item.
As for trailer overhang beyond the bunk supports, a little bit is good since this will facilitate the yard lifting off the boat for bottom painting. But beware of making the bunks too short allowing to much unsupported area in both directions. Short bunks will tend to cause the boat to rock and flex more, thus putting stresses on the hull that it shouldn't experience.
