07-03-2010
Tartan 27' owner
I hope you are able to find some keel bolts in the bilge to check out and tighten (or replace).
I know that some manufacturers built the same model boats (Tartan 27' for example) with keel bolts some years and with an enclosed ballast in other years. On my boat there are no keel bolts so the ballast is enclosed in the keel by fiberglass.
If it is an enclosed ballast in the keel then the 'enclosure' needs to be repaired or completely re-done which does not sound like a quick and easy job.
I would agree with your boat yard though. If the keel is wobbling now it would be pretty disasterous if the keel fell of while you were sailing it. It would be bad even if you were just motoring.
Keel bolts could also be covered by some FRP.
Is there an Islander 26' owners group somewhere out on the web?
Best of luck.
