07-09-2010
All controllers need to be tuned to work properly. A poorly tuned controller will not track well, no matter how new it is. And the proper tuning parameters may have changed if you tend to sail in different conditions than a prior owner who tuned the controller to his sailing preferences.
The "S" shape you describe sounds like the controller is overcorrecting, and its gain may actually be too high. So you should experiment by trying lower gain (and also higher, for comparison).
Many controllers are based on the traditional "PID" control logic (proportional, integral, differential), and have three adjustments that correspond to each (though they may adopt different terminology). The gain corresponds with the "P" part. If your controller follows this design, you may also reduce the "S" tendency by increasing the "D" component.
Take this advice with a grain of salt - I have not actually tuned my autopilot yet. It's on the list (because it has some issues under certain sail conditions), but I have other more important things to work on first.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
