Old 07-09-2010
fixxxer0 is on a distinguished road
lead keel repair
So yesterday I hit a rock with the keel of my '73 C&C 30... my fault, no excuses. Hit it pretty good, stopped us dead from about 5 knots or so.
Bounced around on it for a minute until I was able to back the sails and get off it. Luckily no water instrusion or major immediate damage (other than my pride ha), since the boat sailed back perfectly fine and motored the same.
I'm pretty sure she has a solid lead keel (with bottom paint directly on it) bolted on to the hull. I looked at the keel bolts and they seem as they always did, but I am planning to retorque them to make sure.
Obviously I am going to short haul to inspect the damage I did and look for any cracks in the fiberglass hull (solid and pretty thick from what I've heard) before and after the keel, as well the keel/hull joint around it.
I am crossing my fingers that the only thing I'm gonna find is a nasty fist sized dent in the lead keel and some missing bottom paint. My concern now is how to go about repairing the dent in the lead.
I don't beleive there is any fiberglass encasement to deal with, so its just mangled/missing lead. Anyone have experience or ideas on how to fix this?
Do you somehow weld another peice of lead back in there or just hammer it smooth and epoxy it? Torches involved? No idea what the best approach would be.
Old 07-09-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
this is one of those times where ignorance ain't bliss. The lead is the last thing i would be worried about. if you hit that hard, at that speed, check the leading and trailing edge of the keel stub. I bet you are going to see some cracking. Not a big repair, or a difficult repair, but a necessary one, and the sooner the better.
before hauling out, check around the keel bolts and in the sump of the bilge for cracking/missing bilge paint- this is an indicator that the keel stub has done some pretty major flexing.
Old 07-09-2010
SJ34 is on a distinguished road
Assuming you have no other damage, and the keel is still structurally sound (I would haul and get the opinion of a pro) you can re-fair the damaged area with epoxy filler.
It is very important that the lead is clean and free of corroson. Before applying filler I would recommend sanding in some straight epoxy into the metal to get a good bond and corrosion barrier. It's also probably a good idea to build up the repair in layers with a godd 60-80grit scuff between.
If the repair is going to be more than 1/4" thick I would build up the initial layers with a high density filler like 1/32" chopped glass fibers or cabosil at the least. You don't want to have to fair this stuff so leave some room for low density filler for the final fairing process.
I've done this repair many times with good results. This will also work if the keel turns out to be iron although cleanliness is much more important with iron.
I'll say again just for good measure, this is only a cosmetic repair. You should still do a thorough inspection for structural damage.
Old 07-09-2010
Also look REALLY carefully at any tabbing in the floor area under the sole, esp behind the keel... this is where the evidence of serious flex will be easy to see.. separated tabbing is quite likely given you hit at that speed.
1984 Fast/Nicholson 345
Old 07-09-2010
Thanks for all the suggestions on things to check. The bilge access is horrible on this boat, its 5 or 6 little 5 inch round cutouts in the fiberglass floor that you can barely get your hand into.
I'm gonna make a more detailed inspection on the inside before its hauled on monday. I'm debating whether or not to bother with insurance at this point. If I see anything alarming when its hauled I think I'm going to consider going through my insurance.
Old 07-09-2010
ASA and PSIA Instructor
I banged my '76 C&C 30 keel a number of times. There is no tabbing, wood, or structure around the keel to check out...the keel stub is solid glass generally about 1" thick. Look carefully but from my experiences you should have no problem, other than a divot in the lead and perhaps re-opening the C&C smile on the front lip of the keel.
To fix the divot:
1. File off any disfigured lead.
2. Fill the divot with a epoxy/collodial silica paste.
3. Sand any exposed lead clean, then coat with 2-3 layers of clear epoxy.
4. Sand again and paint.
I would not torque the keel bolts unless you are well versed in the torque setting and the right hardware.
Old 07-09-2010
paulk's Avatar
paulk is on a distinguished road
You should probably call your insurance. They might want to have someone there when you haul. We've had similar incidents. The main problem is at the upper trailing edge of the keel, which gets forced UP when you hit. The keel acts as a five or six foot lever, with the entire momentum of the boat leaning on it: the force is considerable. The force of the keel levering the bow down isn't as significant because the boat cushions it by sinking lower in the water at the bow. Conversely, the upward force at the trailing edge is trying to lift the entire boat OUT of the water (no cushion) focusing the lift point on an area of about five square inches. ouch.
Before applying epoxygoop we take five and ten pound hammers and whang the bulging lead back into a more hydrodynamic shape.
Old 07-09-2010
Gary M's Avatar
Gary M is on a distinguished road
I must say i am not a big fan of the C&C swept back keel design of that era but in this case probably a big plus as your keel would have slid up onto the rock as opposed to a sudden stop. Should have reduced the impact considerably.
Good luck
Gary
Old 07-09-2010
Good luck
Gary
Gary, you are 100% correct that the swept-back keel design contributed nicely to trip-and-go style of impact expereinced by that generation of C&Cs. The next generation C&C went to a much staighter keel - the same vicious rack smack at a first-generation '76 C&C 30 could and routinely did ignore, was season-ending for a second-generation '77 C&C 34.
Old 07-09-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
I just did a keel rebed and it's not for the faint of heart or cheap.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
