07-12-2010
It's about 240 miles via land, and a lot longer via water—probably close to 750 nm if you go around Florida. Also, the oil spill presents a problem with taking it via the water, as you may run into it...
However, there is the Okeechobee Waterway, which cuts across Florida from Ft. Myers to Stuart (west to east), and cuts about 250 NM from the trip.
