Old 07-12-2010
mattu is on a distinguished road
Question Roller Furling Jib, please help
I really want to fit the MacGregor 26D that I just bought with a jib furling rig. The ones advertised on the site are more that what I paid for the boat!
Does anybody know of a place where I could be an inexpensive roller furling jib system?
Old 07-12-2010
The Profurl might be a good choice, at $750 or so. What diameter is the forestay on your boat. This unit only accepts up to a 1/4" forestay.
Old 07-12-2010
dnf777's Avatar
dnf777 is on a distinguished road
I'm new to sailing, and learning much everyday I'm on the lake, but I still haven't figured out why furling systems are so darned expensive! Sure, I know well-engineered, machined gear is expensive, but crow! These seem simple in design and construct. Why the hefty price?
Old 07-13-2010
No kidding, I'm in the wrong business. The margin on these things must be huge.
Old 07-13-2010
Profurl. thanks. I believe its 1/4" but I'll never to verify that. thanks again.
Old 07-13-2010
mpickering is on a distinguished road
I don't think a MacGregor 26 has 1/4" stays. Probably 5/32" or 3/16" typical to a boat that size. That being said, the cheapest furling systems you'll find for a boat that size start around $600 plus shipping.
I have a Schaefer CF-700 Snapfurl system on my Catalina 27. The smaller CF-500 was too short to fit. Defender Industries has the CF-500 for $569. The larger CF-700 is $999 (but I've seen it on sale from them occasionally for $798). A good option for a cheap disposable furler. You can look at the CDI systems as well. Slightly cheaper but don't use ball bearings in the drum. Upgrading to the ball bearings puts you within distance of the Schaefer setup which comes standard with it and is aluminum versus plastic.
Honestly, a furler for a 26 footer like your will run you between $600 and $1100 depending on brand, dimensions, install options, etc. If you want to keep costs down, look at systems you can install yourself. While I prefer Harken, I'm happy with the Schaefer system I have and it is better than the CDI systems typically found on boats this size. The ProFurl B looks like a good option for your boat as well at $750.
I'm no expert. Just passing along what I learned in my research.
Matt
SV Ruff Heeler
1982 C-27 #5052
South River, MD
Laser #10270
Star #5406
Annapolis, MD
Old 07-13-2010
Double post - deleted
SV Ruff Heeler
1982 C-27 #5052
South River, MD
Laser #10270
Star #5406
Annapolis, MD
removing jib from roller furling rhetteleazer Introduce Yourself 1 02-22-2010 12:01 PM
dealing with roller furling jib failures? jbarros Gear & Maintenance 21 11-21-2009 06:32 PM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
