Spring-Assisted Knife - what is your experience ? - Page 2 - SailNet Community
post #11 of 39 Old 07-19-2010
Boasun's Avatar
For working on my own boat I would use a stiff back knife. When working on commercial vessels I carry a folding knife that I can open with one hand.
Have not found a need for a switch blade (spring assisted knife).
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #12 of 39 Old 07-19-2010
Zanshin's Avatar
The problem with spring-assisted blades is that, no matter how good the blade steel is, the spring itself has to be made of mild steel and will corrode away quickly. Use a quality folder - Benchmade, Spyderco, CRKT (Columbia River Knife & Tool) to mention just a few. All make excellent models which cana be opened ambidextrously single-handed. I like the bare-bones models with aluminum housing and would always recommend a semi-serrated edge for shipboard use. This CRKT knife has served me well - I've used it a lot both in and under the water and find it easy to strip if I forget to WD-40 it after use and I keep the edge sharp with a Lansky sharpening kit I have aboard.
p.s. I used to deal in these and I've met a number of the knife designers and they are, without exception, rather strange people - 25% engineer, 25% metallurgist and 50% artist.
Zanshin is online now
post #13 of 39 Old 07-19-2010
The Elephant
smackdaddy's Avatar
CKRT - that's the knife I was thinking of. Thanks Zan.
Jerry had the M16 Zytel I think. Impressive knife that one.
smackdaddy is online now
post #14 of 39 Old 07-19-2010
I carry a spare 3"(?) kitchen paring knife in a belt sheath. No springs, no hinges, no nothing and it is relatively cheap, although it is a good brand with a good stainless blade. It stays razor sharp. Doesn't get in the way. And no, it doesn't get used in the galley.
I like to know that if I really need it fast, all I have to do is pull it out, no flicks, no opening, nothing that could possibly get messed up.
I also have a backup knife inside my PFD, that's a simple "hinged" one like Zanshin mentions, with a nub on the blade so that it can be swung open with one thumb. That one's much shorter, I couldn't keep anything more than two or three inches long in the PFD without a problem about 'folding' it.
hellosailor is offline
post #15 of 39 Old 07-19-2010
QuickMick's Avatar
KAI USA : Kershaw Search Results
made in the USA. i always keep it handy and only use in 'must work' situations. for the day to day i have an assortment of swiss army knives and a smith and wesson tactical.
Smith & Wesson SWAT Assisted Opening Folder 3.7" Black Plain Edge - Knifecenter.com
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #16 of 39 Old 07-19-2010
Not a fan of auto knives
I don't think auto knives are as good as a one hand operation non spring activated knife. I have better grip and control over the knife when I don't have to loosen my grip to push a button. I prefer a good quality knife that I can open with one hand but has a solid lock that moves in front of the blade, not a little notch on the back of it. I really don't want the lock to fail if I need it. My favorite is a Benchmade stryker with a half serrated blade. It opens with very little effort once you get use to swinging it correctly and I don't have to worry about a spring failing, or a legal problem. If auto knives were perfectly legal everywhere, I would still opt for a manual opening knife. There are many high quality knives made similar to the one I posted here, but the design is solid.
Paul2000 is offline
post #17 of 39 Old 07-19-2010
Old Fart
DwayneSpeer's Avatar
diver's knife
I carry a diver's knife on my belt. It has a 3 inch serrated blade and it clips into it's plastic sheath. It's a one hand operation to press the release with one finger while the rest of the hand has hold of the handle. It's very sharp and stays that way.
Hey, can one of you guys pass me a crab?
DwayneSpeer is offline
post #18 of 39 Old 07-19-2010
I don't know what type steel is used
Some probably hold up better around salt water. I would think anything used by navy seals would have to be salt water approved.
Paul2000 is offline
post #19 of 39 Old 07-19-2010
http://www.mikov.biz/knives/BMstryker700.jpg
This is the benchmade Stryker in stainless.
Sorry about doing it in 3 posts, it would not let me post a link until I had a few under my belt. I think a picture is worth a thousand words.
Paul2000 is offline
post #20 of 39 Old 07-19-2010
Sundance 23
carl762's Avatar
I've carred a CRKT M16 for years. It's not spring loaded, but opens with one hand. It has a belt clip. I sharpen it with the Lansky/Gatgo type sharpening system.
Water is Life
carl762 is offline
Knives sailaway21 Gear & Maintenance 29 12-27-2006 03:49 PM
Seeking Experience Epiphany Crew Wanted/Available 1 01-07-2004 04:23 PM
The Spring Launch Bruce Caldwell Gear and Maintenance Articles 0 04-30-2002 08:00 PM
The Spring Launch Bruce Caldwell Cruising Articles 0 04-30-2002 08:00 PM
