Old 07-17-2010
superweeds is on a distinguished road
Question
I intend to buy a sailboat in Newport area, can i navigate this boat up to Lake Champlain? If yes, how much time does this take? thanks
Old 07-17-2010
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
superweeds;623533]I intend to buy a sailboat in Newport area, can i navigate this boat up to Lake Champlain?(Can it be done yes,can you do it, I don't know If yes, how much time does this take? That depends on the boat and weather and do you want to sail 24/7 or stop every night) thanks
Never Forgotten
Old 07-17-2010
its going to be 3 benetau sailboat 33 feet, and yes i d like to stop everynight.
Old 07-18-2010
paulk's Avatar
paulk is on a distinguished road
NY State Barge Canal
Stopping each night will add some time to the trip, but I'm not sure the canal is open at night anyway. If you were to sail the open portions (i.e.: Long Island Sound) at night, it might shave a day or two from the trip. You probably don't want to go through Hell Gate at night on your first trip in your new (to you) boat. You will need to have the mast taken out (in Saugerties?) to fit under the bridges en route, and you'll need crew to help manage lines in the locks. Look up the NYS Barge Canal website for additional details and other posts/articles/books from people who've made the trip.
Old 07-20-2010
mooregm5 is on a distinguished road
Champlain Canal Route
Hello,
Hundred of boats make a similar trip to Lake Champlain each year. I'm more familiar with the Hudson River up to Lake Champlain so I'll keep my comments there.
Assuming you will be holding a normal recreation schedule. Its about 3 days to the Champlain Canal from NYC. You need to go with the tides, or else you make very little headway in certain areas. The Hudson River is tidal from NYC all the way up to Troy (Albany area).
You need to take the mast down before passing Albany. The most-used location are:
* Castleton Boat Club, Castleton on the Hudson, NY; 518-732-7077 --- Note: Do it yourself gin pole.
* Hop-O-Nose Marine, Catskill, NY; 518-943-4640
* Riverview Marine Service Inc., Catskill, NY; 518-943-5311
You can try and sail parts of the Hudson, but you'll be motoring or motor-sailing most of the way. Once in Troy you have 12 locks and 63 miles of canals to reach Lake Champlain. If you have not done them before, it's not too hard. You'll be a pro by the end of the trip.
You'll want at least two people on board, three is better but not required on a 33' boat. Be mindful of your mast on deck, it is very easy to hit your mast against the walls as it sticks off front and back of the boat many feet. Keep the boat parallel to the walls.
The Federal Lock (US Corps of Eng.) in Troy is free. The others are operated by the NYS Canal Corp. and you can buy a 2-day pass (or two 2-day passes if your going slower) at Lock 1 of the Champlain Canal.
On the Hudson stop for the night were you will have your mast lowered (so you can prep the night before and early morning), Kingston, and Croton-on-Hudson.
On the canal there is Waterford, Mechanicville, Fort Edward, and Whitehall. The Canal portion can be done in one very long day (after dark), or better as two reasonable days.
Then put your mast back up in Whitehall at Lock 12 marina, or if you prefer your marina if your located on the southern part of the lake. The southern end of the lake is "river-like" and you'll be motoring until at least the Fort Ticonderoga area.
Good luck and have fun. If your soloing and need help in the locks...PM me, I may be able to help you out for a day or two.
Boat: O'Day 25 / Sea Ray 270 Flybridge
Projects:
Old 07-20-2010
thank you verry much, you are verry kindfull
Old 07-20-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
I'd say if you need to ask then the answer in a definate NO!
Hey, can one of you guys pass me a crab?
Another House v Boat Question creedence623 Cruising & Liveaboard Forum 5 05-11-2010 04:25 PM
Holding tank vent question johnseattle SailNet FAQ's 15 02-02-2010 04:01 AM
Stupid Question krozet Boat Review and Purchase Forum 15 10-11-2009 11:30 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
