Old 07-18-2010
deandavis1 is on a distinguished road
Stability tests. Any engineers or mathematician here?
Hello,
I want to do a practical stability test myself. This is required for survey in NSW Australia. The test is relatively easy but I need some help with calculations (and maybe advice).
I was hoping there might be an engineer, mathematician or physician in the forum who could help me with the following four calculation:
The following steps:
1. Calculate the profile area of boat (with sails and clear sides up) and work out the height of the center of area (ie the centroid of an irregular shape).
2. Calculate the effective force of a 20kn wind on this area.
3. Calculate the weight required to hang off the boom at right angles to simulate this force.
4. Measure the freeboard to calculate the degree of incline.
Thanks in advance.
Dean
Old 07-19-2010
cormeum's Avatar
48' wood S&S yawl
cormeum is on a distinguished road
Originally Posted by deandavis1 View Post
Hello,
Easiest is to just approximate using a triangle constructed from the masthead to the waterline having a foot equal to LOA
that's available on Google
F=Length of boom x weight
Measure height upright and measure height inclined (toerail to water) construct triangle from centerline to toerail (you now have two sides)
You'll calculate the tangent and invert to get the angle. do it again with the boat heeled and subtract to get the angle difference (that's your incline).
see here:
Trigonometric functions - Wikipedia, the free encyclopedia
Thanks in advance.
Dean
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
Old 07-19-2010
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
For GM all you need is the rolling period. Time of going from one full inclination back to the same inclination.
.44 x Beam / time(seconds) = Sqrt of GM.
This is a quick and dirty way of determining the initial stability of your vessel. But it works.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 07-19-2010
Thanks Cormeum.
re point 2, If I have worked out my centroid is 'a' high and my boom is 'b' height and 'c' long, can you point me in the right direction on google to work out the weight needed.
Boasun, I agree with your approach but they are making me do it this way (. The rule says the yacht has to tilt no more tha 25deg in a 20kn wind.
Cheers
Old 07-20-2010
cormeum's Avatar
48' wood S&S yawl
If you know the area of the triangle and the centroid. figure the force on the area in kg/m^2. Multiply by the area to get the total force. The heeling moment will be that force times the height from the water line to the centroid. Add the height of the boom from the wl and go out the boom until the total distance is equal to the height of the centroid. Apply a weight so that g (gravity- 9.8 m/s^2) times the weight equals the previously figured total wind force.
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 08:10 PM
Bluewater defined? dch Learning to Sail 44 07-29-2009 07:20 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
Waves and Boat Stability Michael Carr Seamanship Articles 0 03-25-2004 07:00 PM
