07-21-2010
Part of the solution
Nope. In fact, maybe the opposite.
moisture under cushions is a direct result of condensation. because the underside of vinyl cushions will not absorb it, it simply sits until it evaporates and then ends up back in the same place as it recondenses. An absorbent sheet will not CREATE more condensation, it absorbs what is already there, and because it is locked into the fibres, it does not evaporate as quickly, thereby possibly lessening the amount of moisture in the air.
Note the "possiblies" and "maybes" in the above. All i know is that it has worked for us for the past few seasons. I know longer grimace when I reach under the v-berth and pilot berth cushions to rummage in the lockers.
