Cored deck soft spot repair - Page 4 - SailNet Community
Advertise Here
Like Tree2Likes
Old 04-26-2011
casey1999 is on a distinguished road
What is the story with Epoxy and Polyester? I did not think Polyester would bond to Epoxy. So say I have a fiberglass boat and I don't know if it is poly or Epoxy- do I use Epoxy to make sure it bonds?
  #32
Old 04-26-2011
tommays's Avatar
Most boats were built out of poly with a bunch of secondary poly bonds and did petty good
BUT every piece of original poly secondary bonded bulkhead or other part i have repaired came apart to easy
Any of the original layup done in one piece is brick sh## house strong
So they will both work with the correct technique BUT i have found epoxy to have a lot more ability to be blended with different fillers and hardeners
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #33
Old 04-26-2011
jrd22's Avatar
Courtney the Dancer
Nice job you did and good writeup. Thanks for taking so many pics and posting them, like you say not many actually do this job so first hand experience is hard to get. Goodonya!
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #34
Old 04-27-2011
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Before Dan Pffeifer's PearsonInfo.net website went away, I copied many of the files pertaining to the Pearson 33-2. One group of files was a series of photos of the manufacture of the 33-2 including the deck that one of the original owners of a Pearson 33 had taken. I wish that I knew who had taken the photos because I would gladly credit them here.
Anyway, these pictures show how a BALSA cored deck is built. You can see that the balsa is cut into many 2" squares, and that is how Pearson was able to craft the decks into complex curves.
The deck was built upside down in the mold;
The guys in this picture are laying resin (polyester probably) into the gaps between the little squares of balsa...
The assembled deck curing; (or it was break time)
I believe that the next step would be to cover the entire structure with another, thin, coat of glass roving (or two) and wet it out.
Here is the headliner (built right side up)
  #35
Old 04-27-2011
MastUndSchotbruch is on a distinguished road
Great pics!
Only thing I am wondering how they put the deck onto the inner liner and made sure that they have good lamination between them everywhere? There must be a trick to that. I epoxied a few square feet of a shell onto a substrate (a part of one half of a split rudder) and was concerned that I would have air inclusions. I buttered the heck out of both parts (meaning, onto both parts) and then put a lot of weight (bricks) onto the shelf but in the end I am still not 100% sure there is absolutely no cavity hidden. I can't imagine doing this with a whole DECK!
  #36
Old 05-09-2011
CuriousChris is on a distinguished road
Hi
I just finished removing the rotted core out of the cockpit of my 1975 Tanzer 22. I am completely new to the world of fiberglass boat repair but I eventually got it done. It is rock solid now. Its an area roughtly 24 x 70 inches if I remember correctly.
I expect that I will be doing this in other spots as I discover more wet core.
I've documented what I did on my web site.
Christine DeMerchant Repairs the Wet floor of her Tanzer22
I took quite a low teck approach in removing the rotted plywood because the bottom layer was very fragile. Once stripped out the job went fast and rebuild was easier than I thought it would be.
I use MAS epoxy but any good system will work I expect. I like that it does not blush.
I'm not sure I worked terribly efficiently but I'm confident that my repair is solid and sound.
Have a look, and good luck.
Christine
  #37
Old 05-09-2011
Irrationally Exuberant
arf145 is on a distinguished road
Nicely documented, Christine! Looking at the work made my back ache a little though
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
  #38
Old 05-09-2011
The back took a beating but what was much worse was the prickly fiberglass. I itched solidly for 3 weeks.
My boat club friends suggested a cold shower to dislodge the fiberglass, that seemed just plain sadistic.
What do other people do about fiberglass itch?
Tanzer 22,
hull 866
  #39
Old 05-20-2011
kenatech is on a distinguished road
Cored deck spot repair
Over 10 years ago I was asked to repair a trawler with loose teak decking. When I took up the first section of teak, I discovered that the glass deck underneath was very spongy. The wood core was soaked and rotten, on the bow, stern, and both sides of the cabin. I carefully cut away the top layer of glass, removed all the rotted core, which was lauan plywood. I then filled the core area with good quality marine plywood, totally bedded in West epoxy, then bedded the top layer of glass back into place with epoxy. Once it was all cured, I was able to replace the teak decking. The owner kept the boat until a couple years ago, and as far as I know the deck was still solid. Except for fairly small areas, I believe that replacing the core is the best way to assure that the problem will not recurr.
Tom Kenat
The Ship's Carpenter
Medina, Ohio
  #40
Old 05-20-2011
Thanks Tom
Looks like you're right. There are lots of people offering drill and fill solution but no one is endorsing them (except people who sell it).
I will keep in mind that I will need to gradually open and fix the wood core areas.
Christine
You may post attachments
You may edit your posts
Soft Deck repair Balage Gear & Maintenance 8 04-26-2010 03:49 PM
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
