07-23-2010
Part of the solution
Chris, after perusing your blog, i see that you're making the right decision for you. The Alberg is a pretty boat, but she is a "small" 30 footer, with a narrow beam and long overhangs limiting "living" space.
I disagree with (at least) one aspect of your point of view:
On your blog, you wrote: "I have come to learn there are two types: Those who fix boats, and those who cruise boats, and never the twain shall mix.. I, sad to admit, am not a good fabricator. "
If your goal is to live aboard and cruise full time, the twain WILL mix constantly. Those who CAN'T fix boats soon become those who DON"T cruise boats- Using a used boat for what it's intended use is, tends to use up the parts you use, and you use everything, so you should know how to fix what you use. Otherwise you will find your cruising kitty becoming severely depleted while you spend your time wringing your hands in backwater boatyards waiting for work to commence, to finish, and/or to be fixed.
You think SeaTow is piracy? Wait until you price installing a new engine.
