07-23-2010
Old as Dirt!
Based on my recollection of our Lido 14 (from the early 60's), if you look at the masthead you should find a small inverted V shaped cleat and the main halyard--wire with a rope tail--should have a swaged in "bead" just forward of the tail. The idea is that you hoist the main, pull the halyard out and down and lock the halyard bead in the inverted V. There should be a small pad-eye on deck or on the aft side of the mast just above deck level to accept a single block with a becket. The down-haul runs from the becket, through a small block on the underside of the boom, back to the becket block and than back up to the cleat on the starboard side of the mast.
The Lido 14 was/is a great boat and we had some of our best sailing times on ours. You'll have a lot of fun with the boat. One of the first things you should do is to take her into shallow water and learn how to right her, discharge water over the stern (by doing a push-up on the transom) and then re-board and bail her (keep a bailer on a lanyard tied to the boat!) and you'll be good to go.
FWIW...
