Old 07-23-2010
leeisagenius is on a distinguished road
Where do I find an exhaust elbow
I have an older Contest 27 with a Universal M2-12. Recently the surveyor recommended that I replace the exhaust elbow, but I have had a difficult time finding a part just like mine online. Do exhaust elbows need to be replaced with exactly the same part or will any exhaust elbow work as long as the pipes are the right size and thread?
Old 07-24-2010
sawingknots's Avatar
sawingknots is on a distinguished road
yup,if it will fit or be modified to fit,i fabricated one from stainless for my yanmar
Old 07-24-2010
olgriz is on a distinguished road
I'd suggest you go to a local marine diesel mechanic. The elbows, sometimes called mixing elbows, are made of cast iron and have a usable life of 6-8 years. They mix raw water with exhaust gases for cooling.
I just replaced the elbow on my Olson 911se. Disconnect the raw water intake hose (close the thru-hull first) and the hose that goes into your exhaust riser. Remove the elbow and flange from the rear of your engine and take the whole thing to your mechanic and ask for a replacement. He should remove the elbow from the flange that attached to the engine and install the new elbow. Make sure you get a replacement gasket and gasket dope from him. To avoid leaks when reassembling, make sure you clean the flange face (the part that mates to the engine) and the matching surface on the engine.
I'm not mechanical by any stretch and did the procedure (out and in) in half a day. A mechanical person could probably do it in an hour or less. Good luck.
Exhaust system replacement using mostly Trident? Pub911 Gear & Maintenance 4 05-10-2010 07:06 AM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
