Chemical Strippers & Gelcoat ??? - SailNet Community
post #1 of 7 Old 04-08-2003 Thread Starter
Hi Everyone,
Hoping someone out there can offer some advice on removing the old varnish (possible cetol underneath)from the grabrails and other external fixtures on my C&C 32. Is there a product capable of this task without damaging the gelcoat ????
Thank you,
Terry Clarke
CAPTIVA, Port Whitby
Terry Clarke is offline
post #2 of 7 Old 04-08-2003
marine peel-away will not effect the gelcoat. www.peelaway.com
good luck
hamiam is offline
post #3 of 7 Old 04-08-2003
Ahoy, Marine strippers can be very tricky, be very carefull once you get her coat off cause penicillin isn''t always available at the local West marine and no matter what anyone says always wash your stripper with vinegar afterward to stop the action. Sure giving her cab fare will make her leave but the vinegar really puckers them up!! Pirate of Pine Island
BigRed56 is offline
post #4 of 7 Old 04-08-2003
Ha!Ha!Ha!Ha! Thanks for that one!
Kokopuff
kokopelli9 is offline
post #5 of 7 Old 04-15-2003
I''ve always used the heat gun and scraper approach. Have to be careful though so you don''t burn the wood, yourself, or the gelcoat. I have done this MANY times on our old toe rail. I don''t know about Cetol, but varnish would come right up.
Gerhard
gstraub is offline
post #6 of 7 Old 04-15-2003
Taking a heat gun to the gelcoat is a very BAD idea. It will MELT and BURN. Also, in general, the heat can drive substances into the wood. Try a chemical stripper.
hamiam is offline
post #7 of 7 Old 04-15-2003
I wasn''t suggesting using the heat gun on the gelcoat....just the wood that has the varnish.
Gerhard
gstraub is offline
gelcoat cracks in nonskid fupa Gear & Maintenance 4 09-25-2006 12:51 PM
Please Help! Gelcoat questions...im very confused efiedler Gear & Maintenance 1 04-07-2004 10:16 PM
Gelcoat vs. painted bottom czibailo Racing 2 01-31-2003 02:55 PM
rash decision: applying gelcoat tappers Gear & Maintenance 0 09-18-2002 02:27 PM
moisture trapped between two gelcoat layers tappers Gear & Maintenance 10 01-04-2002 11:07 AM
