Old 08-01-2010
captainrizzo's Avatar
captainrizzo is on a distinguished road
Raymarine ST60 Speed Trouble
I have Raymarine instruments (Autohelm, Wind, Depth, and Speed). My speed display went to 00 while underway this weekend. I still get water temp on the same display, so it appears that it is not the cable.
I keep the paddle wheel very clean at all times. In fact, when I am not sailing, I replace the thru-hull with the blank so it doesn't collect gunk from the Chesapeake. Has anyone had the same issue and what is the remedy? The user manual offers nothing that I haven't already done. Any suggestions would be welcomed!
-Riz
Hunter 306 Domingoman
"It is not the ship so much as the skilled sailing that assures the prosperous voyage"
George William Curtis
My Blog:
Old 08-01-2010
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
Mine occasionally gets a piece of grass or something on it while underway. It usually clears itself after a while.
Old 08-01-2010
newpbs is on a distinguished road
Speed Sensor
I was having trouble with my speed sensor when I launched this season. Long story short, one of the tech folks at Raymarine suggested that I reset the instrument to the factory settings. That fixed the problem. Of course I had to recalibrate the unit, but it worked fine.
I was happy to have the instrument running and I did not have to replace ant hardware.
Paul
Old 11-09-2010
SailAlfin is on a distinguished road
st60 speed paddle
I completely forgot to remove the paddle wheel after a cruise and it got plagued with barnacles. I cleaned it but it is reporting slower than gps speed. Can I replace the paddle by pushing the pin without damage?
Old 11-09-2010
justified is on a distinguished road
Riz
Check your cable closely, mine got pinched right where it came out of the top of the sensor unit. I still had temp but no speed. bought a new sensor and worked fine. You can splice the cable to the old.
Peter
Old 11-09-2010
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Rizzo, assuming everything LOOKS fine and the paddle is clear and installed correctly, try this:
Using a multimeter:
1. With the system powered up, on the back of the Speed instrument measure the voltage between the RED (Speed/+Voltage) wire and BARE (Speed/Ground) - that will tell you if the transducer is being properly powered (ie. no shorts).
2. Power down the instrument and disconnect the RED, GREEN and BARE wires - measure continuity (ohms) between GREEN (Speed/Signal) and BARE whilst the boat is moving or you've got some current under the hull or someone divbes down to spin the paddle - the reading should go from open to short circuit and back open again as the paddle rotates.
3. Reconnect the wires, power up again and try a factory reset.
4. Let us know how you get on.
Good luck!
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 11-11-2010
ffiill's Avatar
ffiill is on a distinguished road
Log will rarely show same as GPS-you cannot calibrate log against GPS-log shows speed through water relative to any current with or against you.GPS shows real speed over the bottom.
Old 11-11-2010
Minnewaska will become famous soon enough
I've pulled mine, wiped off the gunk, spun the wheel in my fingers, replaced and still not received any speed indication. Upon closer inspection, I've found gunk, almost like thread, wound around the wheel's axle that I've had to pick out with a knife. I've also wondered if growth on the hull, immediately in front of the wheel could affect it. I bottom clean about once per month. On the worst late season cleaning, the diver said it was like a shag rug. (yes, new bottom paint this winter)
Old 11-11-2010
ffiill's Avatar
Come across that as well on mine-rule is to keep it clean.Once I got the nerve to pull the self sealing plug I keep mine clean on a regular basis
Old 11-11-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
... In fact, when I am not sailing, I replace the thru-hull with the blank so it doesn't collect gunk from the Chesapeake.
That's such a great idea. +1 I'm adding to your reputation. Thanks!
Regards,
Brad
