Keel modification - Page 2 - SailNet Community
post #11 of 14 Old 07-05-2011
Hi read your post and IM curious as to the cost and were to get info on a keel change on a 272 o'day 1988 will like to do as you have done, know how or were to get a dessing that will work with this hull ?,dont like to get worst performance, like the modern keel with the swept bulb back ,were is the info thanks for any input; changing the mast to ,to a 27 o'day that I have in stock
rancano is offline
post #12 of 14 Old 09-21-2011
please help me to have drawing for swing keel Aquarius Model A23, its totally corroded and cannot immitate the original keel.
ramonroq
ramonroq is offline
post #13 of 14 Old 01-22-2013
Re: Keel modification
Originally Posted by Kwasiemoto View Post
Yes, I would be interested in hearing what you did, and how you did it. I don't want the nightmareish notion that my modification would lead to a disaster any where in my head.
How did your keel mods go?
Dennisail is offline
post #14 of 14 Old 01-22-2013
Re: keel modification
Originally Posted by berecz View Post
I have done the same keel modification on my hunter28 the same way you described, it came out just fine. I did it because where I sail we have lots of kelp.If you vant more information drop me a line
Imre berecz
Does the hunter 28 have a hollow fiberglass keel? Did your boat sail better after the mods?
Advice on glassing in wood keel spacer block bigwalt Gear & Maintenance 35 04-10-2011 07:21 PM
