stuck keel - Page 2 - SailNet Community
post #11 of 13 Old 09-29-2010 Thread Starter
stuck keel-success
Finally got the keel unstuck, with aid of reciprical saw and prying. Thanks for you suggestions.
beetoven is offline
post #12 of 13 Old 09-29-2010 Thread Starter
Originally Posted by CalebD View Post
This is usually caused by marine growth in the center board trunk. Does your Sandpiper sail in salt water? If so then barnacle growth can easily jam up the works.
I'd find a long, thin, flat tool (something like a metal ruler) to use to dislodge any marine growth around the center board and trunk. Mask, snorkel or scuba equipment would also help.
Sometimes going out on a 'bouncy' day (when there are waves) can be enough to free up a snag like this. Unfortunately this is this also the kind of day when you would want your center board deployed.
Good luck.
beetoven is offline
post #13 of 13 Old 09-29-2010 Thread Starter
Originally Posted by Boasun View Post
On the steel Center board. Have the boat on the hard and drop it out and determine if it is salvagable or not. If it is, clean the rust off, pickle the steel then primer and paint it with bottom paint.
On the swollen wood of the CB Well you need to let it dry out then primer & paint it with bottom paint.
But while the CB is out, you can check for dry rot and other ills that may affect the wood structure of your CB well and keel.
Check the pivot pin for wear and the babbit bearing also. Along with the connection point of your CB Pendant.
beetoven is offline
Keel modification Kwasiemoto General Discussion (sailing related) 13 01-22-2013 08:59 AM
Advice on glassing in wood keel spacer block bigwalt Gear & Maintenance 35 04-10-2011 08:21 PM
