08-09-2010
Bombay Explorer 44
Originally Posted by sawingknots
i repeat!if for what ever reason your engine is under too much load there will be an excess of black smoke!!!,if there's not its not getting enough fuel
This would only be the case if the maximum fuel level has been set too high on the injector pump. If the pump is correctly adjusted there may be a small amount of black smoke when the engine is running with maximum fuel commanded or none at all.
However if you have a problem with a cylinder not combusting correctly due to injecto, piston or valve problems you would see smoke under load.
The rpm figure of 1500, is this a constant or does it vary depending on the speed of the boat.
If your variable pitch prop is stuck at in coarse pitch I would expect the rpm to increase as the boat accelerates from o knots and the prop unloads, perhaps not by much but 2 or 3 hundred rpm increase at least.
Is there any chance that your prop is badly fouled. Mine looked like a flower pot after just weeks in Rodney Bay.
If none of the above apply more details of the prop plus a full case history of what was done when and why might help with the diagnosis.
