Outboard motor for dingy - Page 2 - SailNet Community
post #11 of 13 Old 05-05-2003
I agree with camaraderie. You need a 10HP to plane with two adults. We have a 9.8 Nissan which I believe is made by Tohatsu. It weighs 65 Lbs. and it is the lightest one out there for its HP. We have had it for two years. It started on the second pull out of the box and continies to do so.
Sailmc is offline
post #12 of 13 Old 05-05-2003
We have a 10''6" Porta-Bote which they say can handle a 5HP engine that weighs up to 44 pounds (20 kilos). The only engines that would fit within those parameters were 2 strokes. We found a good used Force 4HP 2 stroke which weighs 38 pounds (about 17.5 kilos).
~ Happy sails to you ~ _/) ~
928frenzy is offline
post #13 of 13 Old 05-05-2003
I will second the recommendation of Tohatsu. I have had one for about nine years that continues to start on the second pull. (knock on wood) They are also wonderful people to deal with if you have questions or need anything. They answer their e-mails promptly!
Kokopuff
kokopelli9 is offline
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
outboard zincs SteveHill Gear & Maintenance 1 01-01-2004 10:32 AM
Permanent gas line fittings for outboard? BallastBoy Gear & Maintenance 2 04-08-2002 04:26 PM
Outboard Motor Shaft Length hilly50 Gear & Maintenance 2 05-14-2001 03:50 AM
