08-15-2010
Senior Slacker
Get the long-shaft, if you can. If you have to motor through any large chop a short-shaft OB will tend to pop its prop out of the water from time to time, just when you need all the push you can get (the over-revving that comes with this isn't good for the motor either). A Mirage isn't likely to be as bad in this respect as some other boats, since it doesn't have much of an aft over-hang. But, the few extra bucks it will cost you for the long-shaft will be worth it, even it you only rarely need it.
