30 feet on trailer - Page 3 - SailNet Community
post #21 of 28 Old 10-07-2010
ancient mariner
captbillc's Avatar
my nimble 30 express is about 7,000 lbs i pull the keel stepped mast with the marina's crane , with help from 3 friends. i leave it there for the winter. they load the boat on my 9'000lb cap 6 wheel trailer. i tow it home with my dodge 1500 850 ft up & 25 miles to my house.(315 engine)
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
captbillc is offline
post #22 of 28 Old 10-08-2010
Hake Seawind Eagle, 32 foot and trailerable with a 3/4 ton truck. Most owners have given up their dagger board in favor of permanently mounting a keel which screws up the trailerability. Hake also has an apparatus to step and unstep the mast.
TNDiver is offline
post #23 of 28 Old 10-08-2010
LakeSuperiorGeezer's Avatar
Backing Up Trailer
I do not know how much trailer handling you have done. When I was a kid I used to help my uncle on a farm. Eventually on a tractor I could look over my shoulder while backing up and just automatically turn the steering wheel to make the trailer go where I wanted it. With my day sail I can look out the back window and still have that reflex, but on a larger sailboat I have to use mirrors which meant I have to think about what I am doing and backing up becomes frustrating and time consuming. Eventually I hope using mirrors will become reflexive also. Those folks that whip into a U turn at the boat launch ramp and back in there at a really fast walk without having to pull ahead occasionally because the trailer turns too sharpely have a lot of practice. It helps to have someone guide you who is not overly excitable. I find I cannot depend on my wife for help backing up.
LakeSuperiorGeezer is offline
post #24 of 28 Old 10-08-2010
Overloading Tow Vehicle
To who it may concern: If you want to exceed the recommended limits in your vehicle owners manual for trailer weight, be aware that spring loading, brakes, engine power, radiator, automatic transmission cooling, steering, frame strength, accelleration, steepness of hills (boat ramp?) and other items are all considerations engineers take into account when putting a limit on what a vehicle can tow. In recent years manufacturers of pickup trucks have let the marketing people push the engineers into increasing the load limit with no changes in basic design. If I had a good cooling system, a really long trailer hitch so the tow vehicle is not jerked around as much, and electric brakes that are strong enough to lock up when applied manually, or hydraulic that lock up when disconnect from trailer ball is sensed, then I feel I could push it some on weight if I kept the speed down. However, If I were really sensible, I would buy a vehicle with 30% more towing capacity than recommended in the owners manual if the vehicle is less than 15 years old and be a lot more relaxed while towing. If I bought a 1995 Ford F350 diesel dually (which I have), I would not exceed the owner’s manual limit of 10,000 on the back bumper and forget the 30%. I prefer a manual transmission because I would not have to worry about an automatic blowing up on the road. Also, keep in mind that many of the diesel engines used in pickup trucks are commercial engines that are good for 1,000,000 miles with a valve job at 500,000.
post #25 of 28 Old 10-08-2010
I'd also add that many boat manufacturers are a bit optimistic on the loads that their boats on trailers actually represent. Most boat specifications are a bit on the light side, especially if you consider that the listed displacement is often the "light" weight and generally doesn't account for your gear, clothing, etc., or things like dinghies, sails, fuel, water etc. The "loaded" configuration weight is often 500-1000 lbs. heavier than what is listed, especially as you get boats >25' LOA.
sailingdog is offline
post #26 of 28 Old 10-08-2010
TheWhiteRabbit's Avatar
How about this bad-boy. I think these have a rep as "blue-water" boats, but if you don't want to sail it to the next destination, well hell, just drive it!!!
1981 27ft. Norsea Sailboat
TheWhiteRabbit is offline
post #27 of 28 Old 10-08-2010
The Norsea 27 is very seaworthy and I'm a bit puzzled as to how one ended up in Montana...
post #28 of 28 Old 10-08-2010
Yeah, that's what I was thinking too...There is a huge lake, Flathead lake, in NW MT, but otherwise..... I guess that's why he wanted a trailer-able sailboat, its a loooong way from MT to the ocean.....
Delaware Bay/River Upper Chesapeake get together September? Ulladh General Discussion (sailing related) 211 09-25-2010 11:11 PM
To sail a trailer; deniseO30 General Discussion (sailing related) 15 08-17-2010 10:04 AM
Trailer Sailing - Am I fooling myself? jim2553 General Discussion (sailing related) 13 08-15-2010 06:23 PM
Victory 21 Trailer sctalbot General Discussion (sailing related) 1 08-10-2010 11:16 AM
Liveaboard Between 32 and 36 feet thesnort Boat Review and Purchase Forum 9 08-04-2010 09:05 PM
