- Quick Menu
08-16-2010
Sketchy features on offshore cruisers
I would like your input on some features for offshore cruisers as far as safety is concerned:
1) Portlights in hull
2) Large windows of decksalon/ pilothouse models
3) Centerboard/ swing keel
4) Spade rudder
These are all items, I would like to stay away from in an offshore cruiser for safetyreasons.
Has build and material quality overcome the stigma attached to the above points, or are these still worrysome features?
Thanks for the input.
Bernd
PSC 31
08-16-2010
It depends... there are many bluewater boats that have some or all of the features that you describe and yet they have made passages without issue. Ovnis for example are french built aluminum boats with a centerboard, but are quite well respected for being a very capable bluewater boat.
Properly designed, built and maintained, none of those features should be deal breakers IMHO.
08-16-2010
Splashed
I concur with SD..
With the right materials/build these can be as strong as the hull. Big pilothouse's may be detrimental to windward ability, though.
Depends on stability - refer to the GZ and stability curves for the actual vessel. Like SD said, the Alubat boats (OVNI) and Southerlies (amongst others) are succesfull bluewater boats in that category.
Plenty of boats with spade rudders have made successful blue water cruises.
The answer is YES, correctly designed and constructed, there's no need to worry about these features.
Watch great footage about the story of one man’s slow odyssey around the UK: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
08-16-2010
48' wood S&S yawl
4) Spade rudder
Bernd
PSC 31
It all depends on where you go and when you go there.
Our boat has "none of the above".
Isn't there a "stuck swing keel" thread floating around here?
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
08-16-2010
Sounds like you've already decided on what you think is inappropriate for an offshore capable yacht and are looking for others to support your thoughts. Everything you've asked about can be accurately answered with, "it depends".
08-16-2010
Da Most Educated Red Neck
I think what OP meant is: Can the "boat" follow your "none of the above" boat with ease and comfort. Let's say your boat rated 9 out 10 in ease and comfort. Will the "other" boat be at -5 , 1, 5, or 7 assuming the boat is made a bit better than a Hunter.
Note: No disrespect to Hunter owners. You are still way ahead of me since I am boatless.
Starting 2012 sailing season: Done with the timeshare boat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
08-16-2010
The OP wrote:
"These are all items, I would like to stay away from in an offshore cruiser for safetyreasons. Has build and material quality overcome the stigma attached to the above points, or are these still worrysome features?"
...and for the sake of clarity, what makes a boat 9 out of 10 for ease and comfort? I'm guessing it will be a long and subjective list . Will it have anything to do with the OP's question?
08-16-2010
puddin,
No, I have not made up my mind on these items, if I had, I certainly wouldn't waste your time or mine.
I am interrested in your input, because all these features have advantages that I like in one way or another, but come attached with safety issues(at least for me). As I am looking at bluewater boats that I like, some of these items are part of the boat.
I guess when it comes down to it, I am looking for people to contadict my personal inclination, and give me a good reason to do so.
08-16-2010
48' wood S&S yawl
Were I to rate them by how much they'd creep me out in a bad storm, I'd put large windows as the worst feature by far.
In hull portlights have to my understanding held up well, but they are another area that can fail catastrophically should they go
I don't think that swing keels have been proven in a cruising environment and should they fail it'd be a big problem. Centerboards are well understood and although they require additional beam for form stability, a centerboard fan shouldn't be put off by them for passagemaking.
I personally am not a fan of spade rudders but a lot of boats use them without incident. They have advantages in manoeverability despite their vulnerability.
Note, none of these relate to "ease and comfort" but rather to survivability.
08-16-2010
Splashed
bjung,
It is all myth. You can safely take swingkeel, spade rudder boats bluewater cruising. You have to do proper planning for all types of vessels no matter if they're of the old long-keel type or not, but don't believe in the myth about old long-keelers being the safest offshore boats.
Old wooden boats had long keels because of material, tools, and possibilities, not because that was necessarily the best.
Affordability is another thing, sometimes you can find a great "old" boat that is safe for offshore, but might not be able to afford a newer (well constructed) boat capable of the same thing. Then it's easy - choose the one that takes you sailing.
| Thread Tools |
Search this Thread |
