08-20-2010
I have a seitech dolly for my laser2, 15 ft, probably close to 200lbs fully rigged and with my gear in it to go sailing. Works good. Kittyhawk and some other companies make road worthy trailers that are light enough to use as a dolly too. Standard trailers are too heavy to retrieve by one person unless a block and tackle systm is availale at the ramp. There are lots of home made wood and PVC dolys at my storage area, most are starting to colapse after a season or 2. I think a home built could work, but should be overbuilt as the weight of a wet boat, gear and the harsh marine enviroment seem to take a rapid toll on gear. If you have drag it over a beach the big wide balloon tires are a must have. By the time you buy those, get a proper axel to support he weight the boat, and get the other materials together it might be easyer to just buy one.
