Nonsuch 33 - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 11-13-2010 Thread Starter
davidpm's Avatar
Originally Posted by BearAway View Post
Toppinglift always WELL EASED after sail is hoisted. Topping lift is for boom support and NEVER comes off when sailing a Nonsuch.
I'm 6'2" / 1.8 m and the booms and foot of the sail easily clear above my head on any Nonsuch model . . . 22 through the 40 . . . when I'm standing in the cockpit.
So I am still really confused.
I had the topping lift attached but loose. The boom was sheeted in.
I was motoring with the sail up and the end of the boom was bouncing like a sledge hammer about 3" above my head. I am 5' 11" max
I'm assuming there was something wrong with this boat. What do you suspect it was?
davidpm is offline
post #12 of 22 Old 11-29-2010
Nonsuch bowsprit & headsail = NO
Don't try to fix what ain't broke.
If you want a headsail, buy another boat.
BearAway is offline
post #13 of 22 Old 11-29-2010
The wishbone can NOT bounce much, let alone a lot, with the sheet in trimmed very hard. The masthead will pump in a seaway and as it moves aft, the leech can move down as much as a foot. VERY HARD sheet trim is order of the day in such conditions. If the boom was moving a lot and making the whole rig noisy . . . the sheet was nowhere near hard enough.
Just as you would not motor into the wind and a seaway with a headsail up (nor is it good for any main) you would not do so with the "genoa hybrid" up on a Nonsuch. You CAN motorsail but that means being at least 20 degrees off head to wind.
I've usually found there is not "something wrong" with most boats when there seems to be some problem. I usually found it was an error we as crew made that caused "the problem".
BearAway is offline
post #14 of 22 Old 11-29-2010
Originally Posted by DOKERBOHM View Post
iam new to sailing this type of boat nonsuch 33-- wonder if anyone would know if adding a bow spirt with a self tacking arm would work--- like the ones on island pocket boats--- it would give a lift to the bow which i feel sits low in the water at times and also downwind would increase speed any advice would aprrec. from any nonsuch owners of any size on this manner i have a fabracation shop to make it but need to know if the design of the small self tacking jib would things better or worse????????
dok
Don't try to fix what ain't broke. Don't waste your good money on a bad idea that won't work and isn't necessary. It will NOT increase speed at all except of the money flowing out of your bank account.
Any of the 30 models weigh six tons. How many pounds of vertical lift do you think your proposed idea would generate. You'd need over 2000 pounds of lift to raise the bow a very little while also pushing the stern sections down into the water.
If you want a boat with a rig like an Island Packet buy an Island Packet. If you want a small head sail on "Hoyt" type jib boom, buy another boat.
BearAway is offline
post #15 of 22 Old 11-29-2010 Thread Starter
davidpm's Avatar
This was probably the issue. I was not off the wind very much.
davidpm is offline
post #16 of 22 Old 02-10-2013
Re: Nonsuch sail trim
Hello,
I am very interested in purchasing a nonsuch 33 but wanted your opinion on the carbon fiber masts/booms as opposed to original equipment aluminum mast/boom. Is the carbon fiber an improvement over the aluminum, will it still spill the air sufficiently in gusts, etc. Any advice would be appreciated.
Thanks........Brock
Brocklee is offline
post #17 of 22 Old 02-10-2013
Jiminri's Avatar
Re: Nonsuch 33
In addition to the other excellent advice already offered, I'd suggest that you make sure the choker is tightened HARD. If not, the wishbone can bounce around under those conditions.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #18 of 22 Old 02-10-2013
Bristol 45.5 - AiniA
I think the carbon masts would be a definite upgrade but there were not many made this way. Are you looking at a N33 or N324 (think that is the designation)? The latter is a newer iteration of a N30 with carbon mast. It is not a 33.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #19 of 22 Old 02-10-2013
Jiminri's Avatar
Originally Posted by Brocklee View Post
Hello,
Thanks........Brock
I would not want the carbon fiber, but that's just me. My understanding is that the CF mast is stiffer than the aluminum and the point of the mast is to be flexible. More importantly, however, is that the CF can become brittle. One of our members had his CF wishboom shatter for no apparent reason while he was sailing. I'm not sure that the cause was ever identified, but the speculation was that either the boat had been previously hit by lightning, making the CF wishboom brittle, or had been subject to a some previously unnoticed impact (maybe in the yard) that had caused cracks that finally just failed during his sail.
The 33s are great boats--maybe the best in the Nonsuch line up. I don't need one since the 30 is plenty big enough, but if I had the coin I'd love to have a 33.
West River, MD
Jiminri is offline
post #20 of 22 Old 02-10-2013 Thread Starter
davidpm's Avatar
Re: Nonsuch 33
I came to the conclusion that you just can't motor sail to windward with the boom sheeted in hard and the main luffing like you can in some other boats if you are 6' tall.
That combination with the bendy mast means that the end of the boom is bobbing up and down about an inch from your head.
davidpm is offline
