Old 08-20-2010
davidpm's Avatar
davidpm is on a distinguished road
Nonsuch 33
I was out this PM with a novice sailor and her new to her Nonsuch 33. This is the boat with one large main sail, no stays and a wishbone boom.
The way she sailed it was with the topping lift tight.
This made the sail belly enough so the roach would flip past the topping lift on tacks.
I thought the sail shape would be improved if the topping lift was released which indeed did happen.
With the topping lift loose however the roach would not flip past.
It wasn't too bad but it did deform the leach a little on one tack.
Is this normal on this boat?
Any info on best rig setup?
Old 08-20-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Hi David,
I am more familiar with the Sunfish then the Nonesuch 33' but I have seen them and know the boat you are asking about.
I can understand using the topping lift with this one massive sail to add belly as you described, in light winds. I can also understand your desire to release the topping lift to eliminate some of the draft or belly of the sail in bigger winds.
I wonder if simply removing the topping lift from the boom end and attaching it to the mast base while sailing would be simpler and give the roach all the freedom it needs to tack?
Constantly trimming the topping lift for tacks and letting it out once around sounds like a fairly dubious idea to me, especially in any kind of blow. Having the roach hang up on the topping lift sounds bad for the sail due to chafing.
Is there a boom vang on this boat as well? If so I'd guess you'd use the topping lift only at anchor or in light air and otherwise not at all and it could be detached from the boom while sailing.
The boom vang, traveler and main sheet could be used to keep the sail flatter for higher winds. No need for a topping lift in higher winds.
My $.02.
Old 08-20-2010
Nonesuch boats have a wishbone boom and are essentially self-vanging due to the weight of the boom. Not slacking the topping lift on a Nonesuch leads to lousy sail shape and poor performance. Easing the topping lift sufficiently so that it doesn't affect the shape of the sail should also allow the sail to tack or gybe with little issue. The topping lift shouldn't have to flip from side to side on each tack or gybe.
Old 08-21-2010
davidpm's Avatar
This is the direction I was leaning. Just slack it off enough that it that sail can take the shape it wants to.
I'm used to the roach on the sail of most boats flipping past the TL when tacking. But on the NS it looks like the best strategy is to slack it sufficiently so it dosent matter which side it is on.
What do you think about the idea of tightening it to get belly in the sail for light winds?
Old 08-21-2010
Using a topping lift to support the boom in very light air is a pretty common tactic, and makes good sense—especially on a boat with a self-vanging wishbone setup, which is often heavier than a standard boom.
Clear enough??
Old 08-21-2010
davidpm's Avatar
Clear enough??
Yes thanks.
Old 08-21-2010
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
I had a Nonsuch 30 for a number of years and just left the topping lift lose enough so it did not chafe on the mainsail. I felt that it was there to hold the wishbone when the sail was down. The whole idea of the Nonsuch is to reduce the string pulling to the absolute minimum. Other than standard reefing all you have are the halyard, the sheet and the outhaul to play with.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 08-21-2010
davidpm's Avatar
Thanks, that what I came up with but since it is not what I'm used to I thought I would ask.
Old 08-30-2010
BearAway is on a distinguished road
Nonsuch sail trim
The sail on a Nonsuch is what we used to call (in early '70s) a high clewed blast reacher (heavy genoa). It is NOT a main. Trimming like a genoa works VERY well. Trimming like a main WILL work . . . but sailing performance will be very greatly diminished.
The sail on a 33 is the equivalent of a 150-160% genoa on an average 40 ft / 12 m mast head rigged cruising yacht from the '80s.
The boom weight certainly affects but was not planned as a method to control trim of the the sail, such as vanging. The wishbone "replaces", at the least, 10 ft / 3 m of hull aft of the clew & boom end to which "missing part of the boat" the genoa sheet would "normally" lead for trimming. You figure out how much that amount of hull and deck would weigh (let alone cost) and the comparatively minimal boom cost and weight is a GREAT trade off !
Ed Botterell (Olympic sailor, then owner of HOOD Canada, and builder of many offshore yacht and one design sails) designed the first Nonsuch sail with a small but useful input from Ted Hood. All the other lofts in the world, combined, have not built as many Nonsuch sails as Botts has ever since 1978.
The boom weight (the aluminum booms are less than 200 hundred pounds on a 33 or 36) is a function of what materials were available (and affordable) in the late '70s. The first boat built, NONSUCH, almost debuted with laminated teak booms a la Windsurfers and Freedom 40s of that vintage. THE FIRST aluminum booms were not "curved" but made up from quite a few welded sections . . . the first booms . . . welded sections ! photo - Nonsuch Photo Galleries photos at pbase.com
The weight of carbon fiber booms on the very small number of boats built post 1990 (many have been semi-customs) is less than an aluminum boom on an average 35 ft / 10 m cruising boat.
The foot of the sail "vangs" the sail.
"Choker" trim (similar to but not the same as an outhaul on a main) helps flatten the sail, closes the leech, and induces "vanging" of the sail.
Toppinglift always WELL EASED after sail is hoisted. Topping lift is for boom support and NEVER comes off when sailing a Nonsuch. It may be calm when you try taking it off but if the breeze comes up, even a bit, you'll never get it back on . . . safely. STAY WELL AWAY from the boom end when the sail is up. The sail on a 33 is the size of a main sail on many current 50 ft / 15 m cruising yachts. Would YOU try to go near, let alone hold onto, the aft end of one of those with the sail up?!?
Topping lift trim and adjustment in light air is very useful . . . IF you know what you are doing.
I'm 6'2" / 1.8 m and the booms and foot of the sail easily clear above my head on any Nonsuch model . . . 22 through the 40 . . . when I'm standing in the cockpit. I can't say that about many 40 ft / 12 m or larger sloops I've sailed and certainly not about smaller boats !
The most effective way to motor sail a Nonsuch upwind is to flatten the sail (halyard, then cunningham-if rigged, then lots of choker) and then over trim the sheet slightly (boom end just INSIDE a vertical line, relative to the horizon, up from the gunwale).
Most effective way to make down the boom end . . . when sail is down . . . is with a line tightened down hand hard to ONE quarter (not a "bridle" to both quarters) and then trim the sheet till it's hard. The well loaded and triangular configuration secures the boom end VERY well. If you utilize launches on a mooring . . . use the port quarter, which moves the booms off center to port. If you are on a dock . . . use the quarter and move the booms off center away from the side on which you dock.
Currently own 30C on Lake Ontario and 30C on Gulf of Maine plus an assortment of smaller sail boats and wood power launches.
Have also owned 26C, 33, and 30U Nonsuch models.
The Nonsuch "website" I created and manage . . . Nonsuch Photo Galleries's Photo Galleries at pbase.com
Have also owned and/or raced many kinds of sailboats from 10 ft / 3 m to 120 ft / 36 m.
Cheers
Old 11-09-2010
DOKERBOHM is on a distinguished road
Can A Small Bow Sprit Be Added To A Nonsuch 33
iam new to sailing this type of boat nonsuch 33-- wonder if anyone would know if adding a bow spirt with a self tacking arm would work--- like the ones on island pocket boats--- it would give a lift to the bow which i feel sits low in the water at times and also downwind would increase speed any advice would aprrec. from any nonsuch owners of any size on this manner i have a fabracation shop to make it but need to know if the design of the small self tacking jib would things better or worse????????
dok
