Old 08-21-2010
Daveinet's Avatar
Daveinet is on a distinguished road
Boat speed vs Boat length in light winds
Would like to understand some things about cruising speed as related to boat length. While I understand hull speed and how that tends to limit the boat speed, does length have anything to do with boat speed when both boats are sailing at considerably less speed than their hull speed?
Here is the context: I was sailing in fairly light winds and probably cruising at ~3 knots. Hull speed is 5 knots, so I am no where near the hull speed limit. I am way over sailed for the boat weight and have nearly the same sail area as boats weighing 3 times as much. 184 sq ft 950 lbs full batton main. Sails were trimmed well - meaning I was not having to spill wind to keep from excessive heeling. Under these conditions, I watched a larger Hunter just pull away from me, seemed like he was going about 3 times as fast.
I always assumed that hull speed was for the most part, a "soft" limit, rather than something that dramatically effects the boat at all speeds?
Dave
AFC 17' 2+2
Hobie 14'
Sunfish project boat
Sailing a large boat on a small lake is very tacky.
Old 08-21-2010
LakePirate's Avatar
LakePirate is on a distinguished road
I believe it has something to do with the size of the motor
When a Woman says - Go Ahead: This is a dare, not permission. Don't Do It!
Old 08-21-2010
BigZ is on a distinguished road
In lighter winds where hull speed can't be reached I'd think the main factors would be the SA/D ratio as well as hull shape, i.e., how easily the boat is moved through the water. Some boats don't need a lot of wind to get them moving, others will be slugs until a certain wind speed appears.
Given two boats with similar hull characteristics and SA/D values the longer one would probably have polars that show higher speed in light air than the shorter. Maybe because the exit turbulence/drag for the shorter boat represents a larger part of the equation than for the longer boat?
I don't know... it's been rainy most of the day and I'm PUI.
Old 08-22-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
clean bottoms
A major factor in light winds is how slick the bottom is. Even a little scum will slow up any boat.
Hey, can one of you guys pass me a crab?
Old 08-22-2010
WanderingStar is on a distinguished road
You're right to think that, in general, hull speed is an upper limit. A boat with less drag should sail faster in light winds. This is one of the reasons that classic designs had overhangs: low drag upright, long waterline heeled. But there are other factors too: prismatic coefficient, appendage drag. But in your case it might be that the Hunter's taller rig was in more breeze. Also the age of the sails counts. One of the great things about sailing is that we never stop learning.
Old 08-22-2010
Daveinet's Avatar
I did give that a thought LOL.
I could probably stand to get a good coat of wax on the boat. It is heavily oxidized and the surface has no polish, almost rough to the hand. I also have noticed I drag a lot of water behind me, even when the boat is at hull speed. It just seems with the extra amount of sail I'm flying, the boat should move well in light air. SA/D is 29.88, which by any standard is high. All the numbers say the boat should be fast, but I don't feel like it is.
Dave
AFC 17' 2+2
Hobie 14'
Interesting Sailboats PCP Boat Review and Purchase Forum 2867 12 Hours Ago 02:07 PM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 125 10-02-2011 06:10 PM
Boat explosion finally reaches a conclusion Hartley18 General Discussion (sailing related) 23 10-06-2010 08:24 AM
What not to do Maverick1958 Gear & Maintenance 23 08-23-2010 02:11 PM
Use a DC Power Supply? Tree Electrical Systems 17 08-20-2010 01:03 PM
