08-27-2010
Last Grumpy Old Sailor
Originally Posted by Omatako
Way back in my youth (and that's a long time ago) we used to mess with CB radios and to boost the range we used to (illegally, I believe) use a 3dB gain antenna and it seemed to work wonders for the output.
No, that was not illegal. It was legal to use whatever you wanted for an antenna.
Would these work on a VHF? And are they still illegal?
Yes, but understand: There are no free rides. You cannot create gain from nothing. How so-called "gain antennas" work is much like a flashlight: They focus energy in the desired direction. In the case of vertically-polarized, omni-directional antennas this is accomplished by "squeezing" the radiation pattern down--thus lengthening it on a plane at right angles to the antenna. Visualize a donut on a table-top being squashed down.
Now, this squeezing-down of the radiation pattern is all well and good for fixed land stations, automobiles, and even powerboats, because their vertical antennas tend to stay mostly vertical. But for sailboats it may be an issue, for sailboats may spend much of their time heeled-over at 15, 20 degrees or more. So if you have a very high gain antenna atop the mast: On the windward side your radiation pattern may be pointed off into space and on the leeward side it'll be pointed right down into the water.
And it's a two-way street. It may be difficult to visualize: But as goes your transmit, so goes your receive.
Jim
s/v Abracadabra
1976 Pearson P30
