Old 09-06-2010
Walt352 is on a distinguished road
Smile Grease monkey is the word.
I have a Catalina 30 I bought in Maryland that has been on the hard since 10/01/09. Shipped it down to Florida last week, trying to step the mast and commission her for sailing. It has a M 25 diesel engine that has a lot of grease on it from being winterized. What’s the best way and with what product to clean your engine of grease after it has been winterized without making to great a mess. Thanks Walt
Old 09-06-2010
CaptainForce's Avatar
WD-40 is a degreaser. I would think that spraying with WD-40 and using a disposable paint brush. Think of it as practice for basting next thanksgivings big turkey. Afterwords you should be left with a wiping out of the engine sump. Take care and joy, Aythya crew
Old 09-06-2010
MarioG's Avatar
MarioG is on a distinguished road
A spray can of carberator cleaner and a rag would do the trick. You could also use an old tooth brush to scrub it.
Old 09-06-2010
tomandchris is on a distinguished road
OK, I must be missing something. Why does it have a bunch of grease on it from winterizing?
Old 09-06-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
I am also wondering about the grease.Carb cleaner is VERY flameable I think.Also welcome.marc
Old 09-06-2010
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
Carb. Cleaner will do its best to remove any paint as well.
For diesels WD 40 can also be a combustible, be very, very careful using it.
There are products, magic bright, gunk, meguier make them to name a few.
They don't work as quickly, but give them time, and multiple applications and you'll be eating off the manifold soon enough.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 09-06-2010
Junior Birdman
Iflyka200s is on a distinguished road
Simple Green
Not Flammable, Good Grease Cutter, Earth Friendly..... It's good stuff.
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Old 09-06-2010
Da Most Educated Red Neck
rockDAWG is on a distinguished road
Originally Posted by Iflyka200s View Post
Simple Green
I would up a notch, use SUPER CLEAN DEGREASER
If you can use a power wash and shop vac to suck up the water. DO it right the first time and be done. I hate smelly and dirty engine. ;P
Starting 2012 sailing season: Done with the timeshare boat.
Old 09-06-2010
deniseO30's Avatar
Lies about her age
Driveway cleaner, gunk engine cleaner. ( don't be dumping in the water!)
Pressure wash after presoak. (protect alternator and other electrial items)
Old 09-06-2010
I'd second using Gunk Engine Cleaner, rather than WD-40 or anything more aggressive. Some of the more aggressive things can eat engine seals, gaskets, etc.
I am a bit curious as to why there is grease on the engine from winterizing it. That is totally unnecessary and a royal PITA. If you were storing the engine for say a long, long period of time....two or more years at a minimum, then it might make sense to coat it with grease to prevent corrosion and such from taking place... but for a short layup, it's pretty much unnecessary and overkill.
