Old 09-06-2010
sailorthom is on a distinguished road
help rigging 75 year old sloop
I have an old wooden sloop 18' at waterline, I have never seen it rigged. It has a traveler made of 5/8 bronze the width of the stern with a 3" ring attached. I also have the two wooden single blocks original to the boat with 21/2" sheaves. On either side of the cockpit are two cleats. The jib has a similar traveler with a single cleat on the top of the cabin. There is a hard wooden spar on the jib( the name of which escapes me, senior moment.) I assume it to be a self tending jib. So far I have seen nothing that will help me on the internet or in our library. I want to keep it period correct, so any help would be appreciated. thanks Thom
Old 09-06-2010
deniseO30's Avatar
Lies about her age
Glen L. has an online book "rigging small boats" it's free too! I know the type of traveler you have and it's low tech to what modern ones do with a car and track, and think it was to keep the mainsail tension while the P and S blocks moved it P or S.
http://glen-l.com/free-book/rigging-small-sailboats-2.html]Rigging Small Sailboats - Chapter 2
the link won't work on here, so just type in " rigging small boats" on your search engine. It will come up.
What makes it look period is the use of manila rope, wooden blocks and etc. bronze, Jamestown distributors is a good source.
Old 09-06-2010
Thanks ,actually Glen L was of no help. My first girlfriend was from Bristol PA. "Marlene the Queen" Thom
Old 09-06-2010
deniseO30's Avatar
Lies about her age
You could get allot more help if your provide pictures. Try the wooden boat forums did you?
You can use the book as a guide not verbatum Thom, I've seen the bronze rod and loop type rig. just can't find a pic. Below is a typical set up can be done with yours in old style.
Old 09-07-2010
WanderingStar is on a distinguished road
I second the WoodenBoat forum for this info. But it sounds like your sheets may be double ended, one cleat port and starboard for each sail. Then you can tend the sheets from the windward side on either tack. I'm sure you need more blocks.
Old 09-07-2010
deniseO30's Avatar
Lies about her age
Traveler's have come a long way! LOL
Old 09-07-2010
nolatom will become famous soon enough
Sounds like a basic main traveler of that era, rig the mainsheet on maybe a 3:1 or 5:1 block system, and the ring slides from side to side.
The jib is called "club-footed", and does the same thing as the main. Yes, i too think you need more blocks on both, but it should be pretty straightforward.
What you'll have is a boat that can be tacked upwind on a beat without touching anything but the tiller.
Old 09-07-2010
deniseO30's Avatar
Lies about her age
sure could use that on the river here.. I can tack upwind with the just the main if it's blowing 10 or faster.
Old 09-07-2010
Thanks for the replies. I like the idea of "simple rigging and easy sailing" I will gladly give up speed for comfort. After all,sailing for me is a way to relax . Most of the time I am on a cruise to nowhere,anyway. Is a winch without any provision for a winch handle still called a winch? or is a capstan? Thanks Thom ( I have owned many sail boats including a Soling I don't want to work that hard anymore)
Old 09-09-2010
That little winch is a turning winch I think. I had two of them on my Friendship for the jibsheets. They let you check the sheets or sweat them in. I didn't really find them useful and removed them. I owned a 20' sloop with a big main and club jib. She was very handy and not slow.
amphitrite 43 Sloop Rigged? Kenif Wauquiez 8 08-26-2010 08:05 PM
X-YAcht Rigging Mike36 Racing 1 08-25-2010 02:33 AM
Bad barnacle year so far on the Hudson River CalebD General Discussion (sailing related) 0 08-19-2010 10:26 PM
Cat 22 rigging questions radioguy Gear & Maintenance 5 08-08-2010 12:35 PM
New running rigging PaulinVictoria General Discussion (sailing related) 2 08-02-2010 09:01 PM
