Motorized - SailNet Community
post #1 of 7 Old 04-23-2003 Thread Starter
Motorized
Hi,
I just had a quick question. What is the exact definition of a motorized boat? If you have what is primarily a sail boat, but has motors as a back up that are rarely used, is this considered motorized?
Thanks!
Eligabiff
Eligabiff is offline
post #2 of 7 Old 04-23-2003
Motorized
if you are refering to the rules of the road, then any boat using its motor for propulsion is a motorboat (Eg: when you drop your main, you''re a motorboat)
-- James
jbarros is offline
post #3 of 7 Old 04-24-2003
Motorized
Even more accurately, if your engine is ON even with sails up, you are considered to be under power as far as the rules of the road.
fourknots is offline
post #4 of 7 Old 04-26-2003
pirateofcapeann's Avatar
Motorized
I think the spirit of the rule is this:
Any vessel with propulsion machinery initialed, functional or not, can be considered to be "motorized".
Any vessel propelled by machinery is considered to be a "vessel under power" regardless of what else may be having an effect on it''s mobility.
Here''s a question for the land sharks out there:
If I''m sailing along, with my engine running, let''s say I''m charging my batteries but the prop is not engaged, legally, am I under power or under sail?
pirateofcapeann is offline
post #5 of 7 Old 04-28-2003
Motorized
I''m not an attorney, but I seem to remember a USCG class that said if the propulsion machinery is on, you are under power, even if the transmission is not engaged.
Too hard for other boats to tell the difference, I think, though you are supposed to show a steaming cone if you are using propulsion machinery to drive a sailboat.
post #6 of 7 Old 04-28-2003
Motorized
I believe the steaming cone is only necessary if one is motoring with the sails up.
geohan is offline
post #7 of 7 Old 04-28-2003
Motorized
Ahoy motorheads, Pirate of Pine Island says iffin ye''s got a motor at all ye ain''t much of a sailor. First thing I did when I bought me boat was rip that stinking Ducati desiel, tank and prop/shaft out and promptly threw it in the canal. Damn things still leaking oil!! AARRGGHH.
BigRed56 is offline
