09-12-2010
Originally Posted by Grcesq
Thanks for the input. I will check to see if my halyard is crossed over the topping lift. The sailmaker is very reputable and not far from where I live, in NH. Since there were over over a thousand P26's built he had the schematics/dimensions... plus the old sails to go by. Though it is hard to see, it looks as though I have 6 to 8 inches left at the top of the mast. I will look into an all-rope replacement.
Is it common to have stranded wire and then rope for the main halyard?
From your first post, it sounded like the sail luff was too long. Yet this post indicates its is 6 to 8 inches from the top of of the mast. I'm confused.
Yes, wire and rope halyards were common before low stretch line was available. If the change to an all line halyard will allow you to tension the luff properly, then it might be worth it. I would still talk to your sailmaker to see if he can resolve the issue.
