Stripping the bottom paint - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 11-21-2011
KIVALO's Avatar
Dock
Originally Posted by tommays View Post
For the most part a rigid razorblade holder from and auto parts store will make pretty fast work of bottom paint it is a very easy clean up
A 100 pack of blades is less than 10 dollars as they go dull pretty fast BUT as you refine your style it gets pretty easy to remove a lot of old paint
I am likely to have to redo my bottom in the next year, would you mind expanding on this method? Do you use this like you would for removing the reg sticker from your car? Cant be that way can it? I would think you dig into the gel-coat or worse yet the fiberglass?
Regards,
Brad
s/v KIVALO
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
post #12 of 22 Old 11-21-2011
tommays's Avatar
A 3" carbide PULL scraper turned out the best and even that took 8 spare blades as once they go somewhat dull it really slows down
Home Depot sells there Husky brand and the blades BUT it is only in the store NOT on there web sight
The razor blade was a PUSH tool and dulled pretty easy on bottom paint
Like everything else it took time to find the best angle of attack that took paint and not boat
BUT the barrier coat is MUCH harder than bottom paint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 22 Old 11-22-2011
Gary M's Avatar
A scraper like Tommy,s works pretty well but you will get some gouges. You will need a powerful orbital sander and 60 and 80 grit to get a smooth job. You will take off some gel coat so I would recommend putting on the recommended coats of a good barrier epoxy.
I would allow lots of time, took me about 4 weeks to do a 30 footer with about 20 years of bottom paint on it. I found I could only work at it about 2 hours at a time.
Have fun
Gary M is offline
post #14 of 22 Old 11-23-2011
Learning the HARD way...
eherlihy's Avatar
On a boat that had more things bad than i could count
After a full season of soaking the bottom paint is still happy
THAT is amazing!!! Nice job!
How did you paint the topsides?
eherlihy is online now
post #15 of 22 Old 02-17-2012
jillmstar's Avatar
Just wondering how you got your sailboat in your driveway like that on the blocks?
Blessings
Jill
jillmstar is offline
post #16 of 22 Old 02-17-2012
tommays's Avatar
Gotta have faith in the boat mover and your bow stand
Zzzoom is REALLY nerve wracking
Tommays
Northport NY
tommays is offline
post #17 of 22 Old 04-27-2012
floridajaxsailor's Avatar
Re: Stripping the bottom paint
very impressive work amigo
I am wondering the content of the 'soy based' products
I will be working on a 22 footer next week that just has fresh water alge stains and so forth
any ideas are greatly appreciated
-JD
floridajaxsailor is offline
post #18 of 22 Old 05-03-2012
Cool Re: Stripping the bottom paint
Tommays, great job on the boat. I need to paint mine and need some advise. How long did the job take you, how did you get the boat off the trailer, where did you get the jack stands from, what kind of paint do you recommend and how did you apply it roller or spray it?
castaway is offline
post #19 of 22 Old 05-03-2012
Superior Sailor
Squidd's Avatar
And how much to come over and do mine...?
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #20 of 22 Old 05-03-2012
tommays's Avatar
At some point in time the PO did a really good barrier coat job which i saw no point in damaging as the boat has never had blister issues (knock on wood )
SO i used a carbide PULL scraper to get off the 15 some odd layers and it TOOK a long time perhaps 5 FULL days
BUT your in a time VS money deal and saving time would have cost 2K and removed perfect barrier coat
I scraped to barrier coat and did a fast 80 grit scuff and then did MORE barrier coat and followed up with micron extra in the recommended time frame WHICH is pretty much instantly
The topsides and bottom paint TOOK the most hours in a two year refit BUT if i had and indoor work area it would have taken MUCH less time and if i had HEAT even LESS time
Tommays
Northport NY
tommays is offline
stripping paint bluewhale Gear & Maintenance 3 11-09-2008 12:23 PM
So...I'm stripping the bottom of the hull... parttimesailor General Discussion (sailing related) 25 04-03-2008 07:29 AM
Stripping Bottom Paint SailinJay Gear & Maintenance 12 11-05-2006 12:21 AM
Bottom stripping ronbrockman Gear & Maintenance 4 09-24-2002 03:25 PM
