09-19-2010
The normal 'bilge' tank found in Ty37s is usually aluminum, easily removed and easily 'rebuilt' for little cost.
The aluminum 'water' tank can easily have a new bottom applied, have large access (studded) flanges added, .... to which you can easily apply a 'lining epoxy' and fiberglass cloth (building a FRG tank inside the OEM tank). Significantly cheaper than a new tank .... and the FRG lining makes the aluminum compatible with diesel fuel ... or with chlorinated water.
