Catching Crabs from shore - SailNet Community
post #1 of 10 Old 04-29-2003 Thread Starter
What methods work the best to catch crabs in The Sea of Cortez. Although, I am sure what works one place will work other places. I am talking about catching them from shore not diving for them.
Visigoda is offline
post #2 of 10 Old 04-30-2003
this might be completely wrong ( I live in New England) but I''m guessing that crabs are sort of alike. When I go crabbing here on the east coast I tie a chicken leg to a length of twine and drop her in the water. Let is stay there for 5-10 miutes and then slowly pull it in. Then have a pole with a wire net ready to scoop up the crabs that have grabbed onto the chicken leg flesh
maestro is offline
post #3 of 10 Old 04-30-2003 Thread Starter
Thanks. I''ll try it. I also heard about putting chicken in a nylon stocking and the crabs grab on and get caught.
Visigoda is offline
post #4 of 10 Old 04-30-2003
I see kids on the dock in Newport catching crabs with pieces of string with any type of meat attached. Seems that once the crab grabs on he doesn''t want to let it go. Good luck.
hamiam is offline
post #5 of 10 Old 04-30-2003
You can use a fresh fish-head that you''ve saved. Tie your string to the middle of a nail and thread it through the mouth of the head. It''ll come out the back and the nail will act like a toggle to hold the head on your line and be a bit of a sinker to keep it on the bottom.
LurkerDog is offline
post #6 of 10 Old 04-30-2003
A chicken neck works great also...been using those since I was a toddler.
Kokopuff
kokopelli9 is offline
post #7 of 10 Old 05-01-2003
I believe that crabs are scavengers and will eat just about anything dead.
hamiam is offline
post #8 of 10 Old 10-22-2003
For catching crabs in the Sea of Cortez use the chicken on a string but make sure you season it with chili powder The other way is a triangle trap with a can of sardines wired to the bottom and holes punched in it the smell drives them wild. Oh the triangle trap is a one foot square bottom and four triangle sides with a four string pull and a ring attached to one triangle at the top to make it close when you haul it in.
sailnaway is offline
post #9 of 10 Old 11-12-2003
The other way is to hang out in bars full of after dark girls in San Felipe
post #10 of 10 Old 11-13-2003
On the Chesapeake, we used to call it "chicken necking", after the bait. The crab will stay on the chicken unless you raise it out of the water, so if you use a net, get it low in the water.
mcain is offline
european shore power plugs kimberlite Gear & Maintenance 2 03-05-2003 06:02 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
Off shore sailling obiec General Discussion (sailing related) 9 04-28-2002 02:56 AM
off shore insurance windquest001 Cruising & Liveaboard Forum 1 11-28-2001 07:06 PM
Sailing off shore bsfree Seamanship & Navigation 0 11-03-2001 05:14 PM
