09-28-2010
Large Member
Slick
What year motor? I have a 1991, that impeller is a pain to change.
Have you checked your lower unit to see if water has gotten into it? The 90wt would be white.
I haven't replaced my thermostat but is there only water and a fuel intake track there, no oil?
No oil blowing out the exhaust vents/holes, down by the prop?
Originally Posted by Quickstep192
I have an 8hp Honda 4 stroke for a kicker motor. I recently replaced the impeller, thermostat (required removing the intake manifold), rebuilt the fuel pump and adjusted the valves. Since I put it back on the boat, I notice an oily slick on the water when it's running. If I rev it a little, I'll also notice little white balls that float to the surface then burst at the surface adding to the slick. All of this is with the motor in neutral. This may have been going on for a while and I'm just now noticing because I'm paying closer attention after the work I did. I don't think any of the parts I took apart are areas where oil and water could co-mingle if I put something together wrong, but I'm not sure and that's why I'm posting. I've checked the crankcase oil level and it doesn't seem to be dropping. I also changed the oil to check for water and there's no water in the oil. I ran it for 2-3 hours over the weekend with no problem and it runs well except for the oily slick. I don't see any leaks around the power head. Any ideas?
